Question about Dryers
Tumble dryer failed to start
Having finished a load of drying before the cycle had finished immediately started a new load but the machine refused to start
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 27, 2012
gittos73
  • 244 Answers
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Posted on Aug 15, 2007
  • 8 Answers
SOURCE: dryer shuts down
Probably the motor is getting too hot and the thermal overload switch is shutting it down.Usually means bad motor or dirty motor. You'll have to take it apart to see. Model # and Brand would help.
Posted on Mar 27, 2008
  • 67 Answers
SOURCE: dryer does not tumble, but heats up
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
MNTECH
  • 1543 Answers
SOURCE: LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Posted on Aug 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: anyone know what code t0 means? Dryer will start
To = Thermistor Open error.
The Thermistor resistance is very high.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Replace themistor if out of range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 07, 2010
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
The on switch will not turn dryer on
Hi everyone. I would be grateful for any help. I have a Miele Novotronic T220 tumble dryer. I cannot switch the thing on! The finish lamp is lit continually, and I cannot start another drying cycle.
I have unplugged the machine and pressed the start button again, but nothing happens.
Has anyone got any ideas for a technophobe.
Aug 10, 2008 | Dryers
Dryers Logo
Top Dryers Experts
