Question about Toshiba Ct-90302 Remote Control
Toshiba lcd CT-90302
Tv will turn on and off, but does not display any picture or sound through the tv itself. (sound will work through external source, surround sound bar)
  • Scarter25 Nov 26, 2012
    Posted wrong model number actually the tv model is 55300GU
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
This is not the fault with remote control. It must be the fault with the TV. Check its main power regulator board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 27, 2012
SOURCE: Toshiba Remote CT-877 problem
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Posted on Mar 20, 2008
IrishDruid
  • 2712 Answers
SOURCE: toshiba ct-90275 code for direct tv d10
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: Can't program my Toshiba CT-90302 remote to my DirecTV reciever?
step 1, select the funtion you wish to program on left side.
step 2 hold down the recall button while entering the 3 digit code for the device you wish to program
step 3 have a beer, you are done
Here is the link for the owner's manual that also has the codes
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
Posted on Feb 26, 2009
SOURCE: CANT GET TOSHIBA CT 90302 TO PROGRAM
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Posted on Feb 03, 2010
Como programar control remoto ct-90302 a televicion samsung lcd
If your Toshiba remote is programmable, you can use its code search feature to find a code that will control some or all functions of your Samsung TV. If a search through all codes stored in the remote fails, you may have to try another programmable remote.
Jan 25, 2015 | Toshiba Ct-90302 Remote Control
How do I play movies from my USB hard drive connected to my toshiba CT-90302 tv?
Make sure your TV will accept video files. Most USB ports were made to show still photos and to update the software in the TV itself. Newer TV's can play video files, but make sure the file format is one that the TV recognizes.
Sep 11, 2014 | Televison & Video
How do I set my toshiba remote ct 90302 to my toshiba 40rv525rz
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 05, 2014 | Zt Universal Remote Control CT-90302 Fit...
The input control button not working
Usually there is a input button on the TV itself.
Oct 16, 2012 | Toshiba Ct-90302 Remote Control
My remote Ct-90325 for a toshiba tv keeps saying not available when I press any button
My only suggestion is to read the owner manual to see if the set has a lock out feature that stops the remote from doing any functions.
Jun 13, 2012 | Toshiba Ct-90302 Remote Control
Toshiba tv remote controle ct-90302 stop working try new batteries
I can't speak specifically to your TV, but the problem could be at the I/R (infra-red) sensor at the console. Since our TV sets on a stand (vice being mounted), people like to put things down near the TV and occaisionally obstruct the sensor. If that's the case, it's the easiest fix you'll ever have.
You can test your remote by aiming it at a video camera and pressing a function (channel or volume, up or down) on the remote. The video camera should detect the I/R pulses, and the video display will reveal "light" at the front end of the remote.
Feb 25, 2012 | Toshiba 32AV502R LCD TV
How do I get a manual for Toshiba remote controller model CT 90302
Hello
This remote control is for use with Toshiba 22AV500U TV. It is originally coded to use with this TV, yet other TVs also can be programmed with this remote contorl. There si no specific user manual for this remote control itself. All codes and proceedings are with the user manual for the above mentioned model Toshiba Tv. If you haven't that manual, send your email address to me by Fixya. I'll send a copy of that manual to you by return mail. Or go tho this link from where you can download the above said TVs manual for as PDF format. OK
a248.e.akamai.net/pix.crutchfield.com/Manuals/052/05222AV500.PDF
Sep 01, 2011 | Toshiba Ct-90302 Remote Control
Sep 01, 2008 | Kenwood RC-R0720 Remote Control
Toshiba Ct-90302 Remote Control Logo
279 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
