HP Photosmart C4700 misses lines when printing when printing the top half of words are missing
Not misaligned cartridges, or anything to do with the cartridges. Seems like some kind of software problem.
Blue Hammer
  • 167 Answers
SOURCE: HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Posted on Oct 19, 2007
JmmyPge697
  • 39 Answers
SOURCE: Photosmart c6180 printer is printing
You should first try uninstalling and reinstalling the drivers for the printer. If this doesn't correct the problem, try replacing the cables to the printer.
Posted on May 10, 2008
JOHNNY2hotty
  • 41 Answers
SOURCE: missing 3 mm of print from top to bottom
try goign to print settings, and there you can change the setting for margins and headers and footers.
Posted on May 13, 2008
SOURCE: EPSON STYLUS CX5500;-Document prints from file
send for me manual epson stylus cx5500
Posted on Apr 11, 2009
  • 990 Answers
SOURCE: printer prints every second line
Hello sir; I believe it's time to clean print head and ink cell, power on the machine open the cover ( as you replace cartridge) , when carriage move to the center , then UNPLUG the power cord. then you may move carriage freely by hand all the way to left, noe you can clean up ink cell easily.
Posted on Sep 25, 2009
Testimonial: "Printer is now working fine. However I had to clean the nozzles a few more times . Thank You for your help."
NVM reset for hp photosmart c4780
You can gain access to the service menu...refer to Cartridge Error Clear bypass procedure below (as guidance of how to get in):
For any severe cartridge error related message, on the HP C4600, C4700 or D110a printer models, I suggest you run the internal Tap 41 diagnostics test which will tell you the electrical health of the ink cartridge - in many cases the cartridge is internally electrically damaged and will need to be replaced. In addition, you can temporarily bypass an 'incompatible cartridge(s) or Missing/Not Detected error message by performing the Cartridge Error Bypass procedure...refer to two Youtube videos on how to do this:
HP Photosmart C4600 & C4700 Printers - Tap 41 Diagnostic Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
Low Ink Warning and Other (i.e Incompatible Cartridge) Errors, HP 60 & HP 61 Ink Cartridges:
http://www.youtube.com/watch?v=5_suW3U6e08
Feb 28, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
Misses lines when printing
That is usually a sign that the cartridge needs replacing.
What brand of printer are you using.
Jul 23, 2012 | Epson TX600FW Series
C4680 print cartridge problem
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 06, 2011 | HP C4680 All-In-One Inkjet Printer
C4780 printer cartridge problem cannot fix problem is this same as ink cartridge problem what do i do tried cleaning ink cartridges but still says samething on display it happend in middle of printing...
Ok. As per your statement , the power cable is working properly. So , the problem is with your printer only. If you are using the original cartridges and still having the priblem , it is only the defualt printer. If you are having the extended warnty for (3) years , you are adviced to contact ' HP Authorised Service Partner'. they will replace your old printer with new one. Generally the HP company is giving 1 OR 2 years warranty for replacement.If have paid extra amount for extended warranty , your printer may have warranty up to (3) years. So, within the period of (3), the HP Authorised Service Center will replace your printer. They will give reciept for your old printer, and replace your prionter within a (15) days to (25) days with new one. If the printer is not having warranty or extended warranty , the printer is assumed to be as damaged. So, you have to purchage the new one. Be, cuacious the HP printers are not repairable. Please don't try to approach the local repairer.They will eat your money and also don't try to purchase very very very costly HP in cartridges. I think your problem may be solved.
Oct 03, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
My HP Photosmart C4700 keeps saying the printer cartridge is in wrong. I have taken them both out and put them in and they are correct.
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=m-OM09NvNqg
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=16uXSBwTan8
HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
http://www.youtube.com/watch?v=RTFOBtdthAc
Sep 20, 2010 | HP PS C4780 All in One InkJet Printer
Hp Photosmart C4780 won't recognize new ink cartridges
Switch off the printer and switch on again,Unclip the cartridges one by one and clip back in again this sometimes cleans out the connector pins.This has happened to me.
Sep 02, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
The printer keeps messaging ink on sseveral colours is low but it is not. Have even tried new cartridges but no difference, same message . Seems to be misreading ink level
Some printers need special software (that shipped with the printer) to "tell" the printer that the ink-cartridge has been replaced, and that the ink-levels need to be fully "reset".
Apr 23, 2010 | Computers & Internet
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
Incomplete lines
Replace Black ink cartridge with New HP one, should print same problem in write too if this is the right fix
Nov 21, 2007 | HP PSC 1610 All-In-One InkJet Printer
jasbo
jasbo
