Question about Vtech V.Smile Pocket
No sound My daughter was sitting on the couch playing her vtech cyber pocket and the sound just disappeared. We have tried everything, including replacing the batteries....this is only 2 weeks old. We read some of the posts on other problems and we can't even locate the "reset button" stated in some of the posts.
    Brigadier General:
  • 5,158 Answers
Here is the manual if you don't already have it
http://www.vtechkids.com/_f/_pw/_manual/V.Smile%20Cyber%20Pocket.pdf
resetting that is apparently just a case of removing the batteries and adaptor (if you are using one) wait five or ten minutes... reconnect the adaptor or install the batteries and turn it on
Robert
Posted on Jan 10, 2009
I NEED TO FIND THE OWNER MANUAL FOR THE VETCH
http://www.vtechkids.com/_f/_pw/_manual/80-075300%20V.Smile%20Pocket.pdf
Feb 18, 2011 | V.Smile 80040571 Vsmile Cyber Pocket Pink...
I cannot get the V-smitl pocket to power up. I have put brand new batteries in it, I plugged it into the car car charger, no luck. I cannot get it to do anything. Please help.
I did two things for my son's cyber pocket - first I took the batteries out and pressed the buttons inside the battery area for over a minute - put the batteries back in and it didn't work. Took them out again and pressed the on button for over a minute and then put the batteries back in and it worked again. hope this helps
Jun 28, 2009 | Vtech V.Smile Pocket
V tech pocket smile
Hi i'm Ryan, my daughters did the same thing, I removed the battery cover and there is a small pin hole with a reset button in it, try resetting it. I did and it came back on and works fine.
Dec 29, 2008 | Vtech V.Smile Pocket
V-Tech Cyber Pocket Screen will not work
Hi i'm Ryan, have you tried to reset it? Remove the battery cover there should be a small pin hole with a button in it, push it to reset. It worked on my daughters.
Vsmile cyber pocket not working
Hi I'm ryan, try resetting it. Remove the battery cover, there should be a pin hole with a reset button in it. my daughters did the same thing and i just reset the system and it works fine.
Dec 25, 2008 | Vtech V.Smile Pocket
My daughter v smile pocket does not work
Sounds like the contacts on the games need to be cleaned. On the game cartridge, push back the little cover and clean the gold colored contacts on both sides. I use a cotton ball or q-tip with alcohol on it. Let it dry before you put it back in the v.smile.
Dec 09, 2008 | Vtech V.Smile Pocket Pink Electronic...
Vsmile pocket - sound OK but blank TV screen when using with TV
Make sure that the yellow is on the same port as the white. also, make sure the yellow port is not labelled OUT or OUTPUT.
Nov 13, 2008 | Vtech V.Smile TV Learning System
V smile pocket
Get an adult male to check jack and see if something was jammed inside, next open it up with screwdriver to see if anything is loose or contact manufacturer since warranty is usually a yr.
Nov 07, 2008 | Vtech V.Smile Pocket
V smile pocket problems
Do you still have your receipt? You could try to echange it at the store. Vsmile is coming out with a newer slightly different handheld model you could try. Though, we have a vsmile for the home and a leapster as a handheld game. Which both of my children have loved. Have you tried calling Vtech about the problem? I've had to call before about the home unit and they were very helpful. (Incedently, I have had problems with that, so if you ever do here's a helpful tip: Reset the machine by unplugging EVERY cord and pressing the two front buttons together for one full timed minute! We were having problems with a power issue and this solved it) They may be just as helpful as Leapster's Leap Frog company and send you a replacement! Once on a long car trip my daughter got sick in the car, while playing, so needless to say the game system got it too. And when I called Vtech about what to do, they sent a replacement! Try calling Vtech and see. You never know! Good luck!! :)
Sep 05, 2008 | Vtech V.Smile Pocket
Pocket Vsmile
Maybe you have to buy a new rechargable battery pack. I have had one before and for some reason it no longer charged well. It too would hold a charge for only a small period of time, definately not long enough to appease my daughter! :) Try giving vtech a call and see what they say. At the very least they can help you get a new pack. Here's the number! 1.800.521.2010 :)
Aug 24, 2008 | Vtech V.Smile Pocket
Vtech V.Smile Pocket Logo
488 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
