Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
Northstar Generator 9HP briggs no eletrical output.
I have a Northstar pro series 5500 with a 9hp Brirggs Vanguard. I was running a welding machine off the 220 outlet and it stopped putting out current. I removed the panel and checked all breakers and connection with no results. I then removed the generator cover and did not see any damage. It has a capaciter but I am not sure how to test it. I did check the coils for resistance but am not sure if I did it correctly. I also do not know where I can get replacement parts. Any help would be greatly appreciated.
  • Ron Jones
    Ron Jones May 11, 2010
    What is the input voltage and ampage,
    is the output AC or DC
    are they (generator and welding set compatable
  • 3 Answers
SOURCE: Northstar 5500 9HP Generator
Ok, try and take the bowl off and clean it out with some carb cleaner. Also open the carb top and shoot carb cleaner down it for several seconds repeatedly. If it has never been used it still was started and tested at the factory. It has gunk build up on the nedle and is probably stuck. This happens to alot of carbs even sitting for only a few years. Just take the carb apart as much as you feel comfortable with and spray carb cleaner all through it. Move the movable parts alittle and then try it. It has to work . P.S. Look in the gas tank and see if there is any rust in it. If so you need to pour some deisel fuel in it and sloush it around and dump it.
Posted on Dec 19, 2008
  • 905 Answers
SOURCE: low output from NorthStar 5500PPG
There are a few scenarios that can cause this.
1) The extension cord that you are using is too long / too light of a guage. Try a heavier extension cord, or plug directly into the generator.
2) The alternator has lost its "residual magnetism" and may need to be reflashed. Consult Northstar for instructions and details.
3) The voltage regulator (actually a simple capacitor) may be "weak"
4) The diode for field winding may be bad.
You can get a copy of your manual here, page 40 has diagram and part numbers.
http://www.northerntool.com/downloads/manuals/165911.pdf?cm_ven=natural&cm_cat=netconcepts&cm_pla=Google&cm_ite=http%3A%2F%2Fwww.google.com%2F%26
Posted on Aug 25, 2009
protek480
  • 1723 Answers
SOURCE: 9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Posted on Oct 01, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a northstar 13hp 8000ppg generator. I was
Hi Doug. Welcome to FixYa I am Kelly. Download this manual and use the applicable section for troubleshooting your Generator.
www.gen-parts.com/Manuals/85680.pdf
What concerns me is you said "there is no current anywhere."
This lead me to believe that given at the time of failure you had a light load on the unit that maybe something simple like a wire has vibrated off a connection somewhere.
Is this a brush type or inverter type generator? If it is a brush type one brush getting hot and moving away from the slip ring assy will cause the exact same symptom.
With the brush block installed you should read a low resistance across the brush block terminals.
If you remove the brush block and one brush is longer than the other one suspect the brush block as the cause.
If it is an inverter type generator there are two types one with an inverter electronics box and the other with one or 2 large capacitors. The one with the large capacitor if the condenser wire has come off or burned, the field will not flash. (Common issue)
There is also a 4 post diode block that must be functioning correctly to have a generator output. There is one terminal 90 deg out from the other three that is the positive terminal. It should read to all other posts in one direction and not at all in the other direction. (meter leads reversed)
This should be enough information for you to isloate the problem. If not just respond here and we can walk through troubleshooting your generator after you have the manual and have done some basic troubleshooting.
Thanks for choosing FixYa.
Kelly
Posted on Jul 30, 2010
ROMOAS
  • 97 Answers
SOURCE: Hello, Bob here. Trying to repair my NorthStar
on the end of the rotor their is a Diode as well as a varistor these will go bad common in these units and cause a power loss these are attached to the rotor by a strip some like a pc board some a insulated tang to say remove the 2 one on each side Diode part# 778959 varistor part# 778961 manufacture numbers you should be able to go to any electronic store like radio shack and cross ref the numbers as to the diode i don't have the spec's but when you find it it will have the voltage rating get the next size up it is better to go to a higher voltage what the diode does it acts like a 1 way valve power flows one way and if their is a spike it wont allow it to come bach and damage parts before it it will also act like a fuse to sorts to much it will pop. the varistor varies the flow their sensitive and adjustable if purchased from other than manufactures factory it will need to be adjusted hope one is good and use a multi meter and test the Resistance and adjust the new one to that spec as close as you can at the end plate their is a capacitor part # 778958 replace this as well again go a higher volt rating but do not change the MF value with this said and done.your will have a more stable sign wave and beefier circuitry able to hold up better use lock tight on the screws for these.ther is not any control in the box with the plugs just breakers after replacing these parts and there is still no power then the stator is shorted and will need either re-winding or replaced.
hope this helps.
Posted on Sep 01, 2010
Briggs 6200 elite generator. Starts runs good no ac output and display is blank
http://www.ebay.com/itm/BRIGGS-STRATTON-GENERATOR-OPERATORS-MANUAL-ELITE-SERIES-6200-RUNNING-WATTS-/401042177246 $14.95
May 30, 2016 | Briggs Electrical Supplies
Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
Generator will not run
Check the battery and make sure there is enough charge in it, check to make sure the contacts are clean and tight. if this does not help then more information is needed
Aug 13, 2014 | Briggs & Stratton Home Standby Generator...
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Adustments engine speed low rpm
You cannot adjust the voltage output. All generators are rated for 110-125 volt recepticals and usually have at least one 220-240 volt receptical for special appliances that require it such as water heaters, pumps, welders, air conditioners. When one of these higher draw appliances is connected and they begin to draw amperage, the gas engine will automatically increase rpm to produce enough amps. If your generator gauge is showing low voltage such as 60,80 or 90volts for example, then you have overloaded the generator and blown a capacitor, resistor or similar item.
Dec 05, 2013 | Northstar North Star Honda 13hp 8000 Ppg...
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
There is absolutely no voltage output. What
My generator has a switch to turn on the output, you must turn it "ON" to get power.
Jun 10, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Low output from NorthStar 5500PPG
Apr 02, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
433 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
