Question about Sony Handycam DCR-DVD205 DVD Camcorder
Problem useing tdk dvd-rw
I used a tdk dvd-rw on my sony handycam. I finshed recording. I then finalize the disc, copyed disc on to computer then erased the disc. The problem is when i put the disc in the hanycam (dcr-dvd205) i get this error message c:13:02 disc error remove disc. please can you help me. danny
  • timmy1010 May 26, 2008
    I've had a similar problem regardless which brand dvd-rw I use.
    President:
  • 4,402 Answers
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Posted on Feb 11, 2008
Can not get video files from a mini dis dcr dvd 108 handycam when I try to import to my pc it says does not support this dis i was using usb cable to pc with sony's software thanks jim
First make sure to finalize recorded disc in camcorder, finalization option is available in camcorder menu and will be enable by powering camcorder with AC charger/ adapter.
Now you can transfer movie files in computer or put recorded disc in computer dvd rom and copy files.
Jul 31, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Sony Handycam says movie recording disabled. How did this happen and how do I undo it?
Follow this procedure to troubleshoot when Recording disabled is displayed by the camcorder.
  1. Verify the disc being used has not been finalized. It is not possible to record additional video on a finalized disc.
  2. Attempt to record on a different disc.
Aug 02, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Dcr-dvd201e sony handycam formated disc (very important pictures erased)
If the disk has been finalised, it cannot subsequently be formatted. If it has been formatted, then it had not been finalised.
May 05, 2017 | Video Cameras
Camcorder disc footage not viewable
try to put it on your dvd rom of computer and see if its working. if you can see the files on your computer, then burn it in nero sofware. so that i will watchable by your dvd player. hope that helps!
CHARCOIS
Oct 02, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony Handycam disc error when i try and finalize it
what type of disc--r -rw +rw? try to finilize in someone elses camcorder if possible and see if it reads it-does it play in camcorder still?
May 06, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Finalize cd-rw on Sony HandyCam DCR-DVD92
hi dear
you can finalize your dcr in record position
going to disc manager find the finalize
and finish
oke
Mar 28, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Mini dvd's not recognized by pc
I had a similar issue at first... needed to ensure that I had the Sony Picture Motion Browser Software downloaded to the system and then it was ok.
Tom.
Mar 14, 2008 | Sony Handycam HDR-UX1 DVD Camcorder
Sony Handycam DCR-DVD205 DVD Camcorder Logo
322 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
