Question about Hitachi 60UX54B/55K 60" Rear Projection Television
T.v. will distort in the corners
All four corners will distort and create an oval shape. if i tap the side the picture will go back to normal this only happens about 2 to 3 times a day. my t.v. is a 60 in rear projection and it is about 8 yrs old
  • boxox14 Feb 14, 2009
    my hitashi 60' rear pro. goes to oval after tornon. if i hit it it will come back to full screen sometimes. if i tap the place where the three wires[red] feed into a grey unit[tall and grey] it will come back to full screen. do i need to replace the tall grey unit? the tv is 11 yrs old and the service guy wants $185.00 just to show up! what do i do?bill from pei canada
    Genius:
  • Hitachi Master
  • 1,635 Answers
There is probably some cold solder connections on the circuit board, or with some of the connectors that are working with the pin correction and or convergence circuits.
An experienced TV service man should be able to service this for you. These types of faults can be time consuming to locate and service.
Considering that the set is 8 years old, I would be seriously looking at a new set! As the set ages its reliability will decrease. Investing money to service it does not mean there will not be other problems with it.
Jerry G.
Posted on Jan 10, 2009
My hitachi 55" ultravision hdtv has a green pear shaped color on the screen, only when it has a dark background, other than that no distortion, no blueing in the corner, no blurriness, nothing. What i
Damaged Optical light engine, this is not the only Hitachi with this problem the ones before the oval was red and was finally settled two years ago in a class action lawsuit.
Dec 15, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
I was watching my HCL4715W TV and the picture
It sounds like one of the convergence Ic chips is bad---you will need to locate and replace both of them and look for any damaged parts around them; there usually are two pico fuses in this area, one for each IC. The fuses do not look like glass fuses--they usually are green or orange in color and will have the amperage marked on them and on the top of the circuit board.
Aug 09, 2009 | Samsung HCL4715W 47" Rear Projection...
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Color gets distorted and picture is narrower
there is a bad solder connection that needs investigating
Nov 26, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Blue Half-oval on screen
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Hitachi 51F510 51" Rear Projection...
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
Distorted picture
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when doing tests. Best of luck, hope ya fix it.
Jan 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
