Question about HP DeskJet F380 All-In-One Printer
The usb cable that came with computer doesn't seemto work on our f2200 all-in-one . do we need to buy a new usb cable?
    Genius:
  • 2,120 Answers
Wierd! Buy the cheapest one you can find. I buy many at Rite-Aid.
If replacing doesn't work,delete printer then delete all USB items in Control Panel/system/Hardware and reboot.
Posted on Jan 10, 2009
IMac deactivates USB port when I connect my Nikon P300
Try connecting the camera directly to the computer, without going through a hub. If that doesn't work, then buy a card reader.
Apr 20, 2012 | Nikon Coolpix P300 26246 4.2x Fast F/1.8...
Nexxtech external USB hard drive stopped working. Light comes on but drive does not seem to activate and produces no response in the laptop.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
a cnet rview
Pros: Lots of space, very low price, doesn't require outside power
Cons: Sometimes stops working, no firewire (but still a quick transfer speed)
Summary: This doesn't require outside power, but sometimes you need to hook it up to 2 USB ports. The USB cable has 2 heads. Sucks when I only have 3 USB ports on my laptop.
Also sometimes it spontaneously stops communicating with the computer. I don
Oct 04, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
My 6530 works OK as a copier but not as a printer or as a scanner. I suspect that the USB interface is defective.
It is could be a software related problem. Software called drivers are needed to run the printer. The drivers for your printer can be found on the CD disk that came with your printer. They can also be downloaded from the manufactures website, click their downloads/support button and select your model of printer. Download and install the drivers for your specific model of printer and for your specific version of Windows.
Take care!
damnor01
Aug 13, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Can I buy a USB cable at any store?
Most stores have then yes, just make sure to get the right kind, meaning micro, mini, things like that,brand doesn't matter
Aug 05, 2011 | Toys
I keep getting a connection Error Message. Please Check that USB cable is connected and power switch is turnedl. I just upgraded to a new computer from and older model computer
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. If you're using a laptop, keep trying different USB ports until you find one that works. Good luck!
Apr 29, 2011 | Singer CE-200 Quantum Futura Computerized...
I wanna to download multi purpose hp- f2200 to my lap-top with win.7.while the cd i got with the printer does not include win.7
I would check with the manufacturer for a Win7 driver. If there isn't one then buy a new printer.
Mar 17, 2011 | Computers & Internet
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
I can't get my computer to recognize my Garmin 255w on USB cable.
Change the mini usb cable. Some mini usb cable are for charging and not data. It happen to me and used the externo hard drive usb mini cable and zapppppp my computer nows read the gps and gave it a drive (h:\). hope it works for you.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
I need a USB cable 4-pin Mini I-Link
Check your computer user’s manual, if your computer doesn’t have a Firewire port, you need to buy an IEEE1394 card to install in your computer and a firewire cable to connect your Mini DV. Check with your local computer store
Jun 03, 2009 | Sony Handycam DCR-PC100 Mini DV Digital...
HP F2200 all in one/ usb
As you are receiving the USB device not recognized whenever you plug in the USB cable, the problem could be either due to the corrupted USB drivers on your computer or the USB cable needs to be replaced. Try updating your USB drivers and/or replace the USB cable. I am sure that the issue will be resolved.
Nov 23, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
Seeker5211
Seeker5211
