Question about Sharp R-1500 Microwave Oven
Clock works but No carosel turning or heat to microwave. Model R-1501 sharp
  • Sharp Master
  • 9,098 Answers
This is probably a bad bottom door switch or its mount is broken or misaligned.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 11, 2009
Sharp model R-320F carousel doesnt turn but it lights up and doesent make any noise
Your probably have a defective bottom door switch, or that switch's mount is bad.
This is a very common probpem in Sharp-made microwaves.
See a help file on door switches here.
The full service manual is here.
You can order Sharp parts from Encompass here.
Dec 11, 2012 | Sharp Microwave Ovens
I have a R-8520 Sharp carosel microwave. Previously the convection stopped working, now it does work but heats up too much to the extent that fumes come out from the back of the microwave and it smells of...
I think it might be a good idea to consider having the appliance replaced, the unit is a fire hazard and judging by the burning smell it is on the way out.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Model R-1405, the carosel stopped turning. that's it. I can manually turn the carosel and I do hear the gears and motor manually turning.
It may be the turntable motor or a bad connection on the control board, especially at the connector, or a bad turntable motor relay.
We have the actual service manual for this model and have uploaded it to our site here to help you.
If your controller needs repair, we do that for $39.95 in most cases. Details are here.
You can buy the motor and other parts at Encompass here or call them toll-free at 866-779-5835.
Jan 11, 2011 | Sharp R-1405 / R-140 Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Outside caseing heating up while cooking`
Also, Please reply back with your brand and model number so we can help you.
Nov 20, 2008 | Sharp R-1480 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
Sharp R-1500 Microwave Oven Logo
44 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
