Question about NetGear WGT624 Wireless Router
Works for short time then all lights blink
When i shut off dsl modem (verizon) turn back on after 5 min.
connect net gear wireless wgt 624 it will cycle lights normally
for a short time and i can get wireless. some times lasts 5 min sometimes 1/2 hr. all lights will blink simutanious and loose connection. modem still works fine ?
  • 20 Answers
U ned to make sure router has been properly configured.u may give a try by logging into the router webinterface using 192.168.1.1/routerlogin.com
once u have opnd the router page clik on "basic settings-no and apply the settings",then clik on "router status" and check for ip address internet port(should not be o.o.o.o),if it has some numbers(perfect),then clik on "wireless settings" under "setup" and do all the wireless settings as per requirements
i hope u will try to do all these steps
Posted on Jan 13, 2009
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
I have Verizon DSL service on my Westell 327w. It
whenever the connection drops, is the DSL light blinking?
because, it is just normal for the E1 light to blink, but the DSL light should be solid at all times.
It can be a possible issue with the cable or the LAN card, but you still need to have your line checked by Verizon to make sure that it is not a modem or a network issue.
Feb 21, 2010 | Westell Wirespeed VersaLink...
Blinking light on Westell 6100 DSL modem
I have a westell 6100 modem also- The light your are talking about always blinks- it blinks as long as the internet is working (it is sending and transmitting data)
May 28, 2009 | Westell Wirespeed LiteLine 6100...
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
Blinking light means that firmware on your DSL modem just got updated. The modem is pinging the Networ/Computer connected to it. If you open your Modem Page 192.168.1.1 you will see the difference, unless you never have done it before.
Jan 25, 2009 | Westell Wirespeed LiteLine 6100...
Verizon DSL spotty service
to answer your first question, call verizon to fix the line. it is dropping. Second have verizon change a dsl and test it out.
as far as the tab on the CAT-5, the tab is to lock the cable in place, without it, it will work but you have no insurace as to the connection status. (need cable with tab).
Jan 18, 2009 | Computers & Internet
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
Cisco vpn will not work with verizon service now after we got a new modem through verizon
Verizon Home DSL service uses a special filter that prevents ALL incomming connection including web, email and VPN hosting from a home connection. Business internet does not limit this, and I don't believe FIOS blocks it. If you have verizon home, there's nothing you can do. If you're just trying to connect to a home machine, you can try something like gotomypc, or a free alternative like teamviewer.com or logmein.com.
If you don't have verizon home dsl, comment back with what service you do have, and we can try some other things.
Steven
Jul 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Di-624 stopped working
Hi sailaway!
. Make sure the router is going from the modem, to the port marked WAN, on the 624. You can test the cable, by plugging it directly into you computer, from the modem, if you want to. Disconnect the power from your modem, your router, and turn off your computer Wait 1 min. Turn on the Router, wait three full min's. Power up the 624, and wait one min. Power up the PC. Reason for the long wait on the modem is that it has to get data from the internet, to give to the router. If that don't hwlp, try changing the cable from the PC to the router, to a different port. If all that don't work, try resetting the router by gentley pressing a straightened out paperclip into the reset hole in the back. Hold it for 30 sec. If that fail resetting it, try holding it in while you unplug the 624 and plug it back in. If it resets, go thru the first steps to set it up again. If all that fails, your 624 may be bad. Had that happen to me. The steps I listed brought it back to life for about 2 months, and it died completely. Good Luck!
Jan 05, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Westell Linksys 327W
Ok right I love these issues. Here we go!! First I want you to determine if this is a no sync issue or if this is a no route issue. Know this is the difference between working with Verizon or working with Verizon On-Line. If you have a sync issue which means the DSL light is off or blinking, this would be a Verizon proper issue and is easy to have fixed, however if the DSL light is on and the internet light is off this means that you have not received a PPPoE derived address and thus while you have DSL (Digital Subcriber Line) sync you do not have connectivity to a gateway router to route you to the Internet. I want you to log into you DSL modem (http://192.168.1.1) then using your login ID and Password the one you configured for the Router not Internet access. And the go to the screen that show your DSL connectivity see if it is up or down *Remember DSL refers to the layer 1 connectivity, and PPPOE refers to the layer 2 connectivity". If the DSL light is on this meaans that you have to call verizon and say "My DSL light is on, but I am not getting an IP address which means my layer 1 connectivity is working, but my layer 2 PPPOE connectivity did not provide the platform for my layer 3 level to be built". so this now becomes a task of troubleshooting the layer 2 systems (PPPOE server, and IP Address delivery systems, and Redback SMS). Instead of a half hour of "is your modem plugged in". If your DSL light is off then your layer 1 systems are not working this could be anything from your modem to the ASAM ( ATM Subscriber Access Multiplexer ) system or DSLAM (Digital subscriber Line Access Multiplexer). In any case if the DSL light is off they just have to figure out why. This can be done at the central office by disconnceting your cable and pair and trying to sync up at the vertical shelf (Ca/Pr) or at the split bank. If they sync up the problem is outside, if they do not sync up the problem is inside the CO either at the Split bank or the DSL OE block. If the problem is in the CO they will fine and fix it. If the problem is outside, what you can do to expedite things is to take your DSL modem to the NID (Network Interface device) and connect to the phone line that has DSL on it and try to sync up there. If you can sync up the problem is inside of your house, if you can not sync up the problem is outside of your house prior to the NID and thus is verizon's responsibility. I hope this helps.
Sep 06, 2007 | Westell Wirespeed VersaLink...
NetGear WGT624 Wireless Router Logo
90 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
