Question about Sector 2653940025 Wrist Watch
How a chronograph watch works?
I got a new chronograph watch. but the instructional book is not more precised...I do not know how everything works or what are they for?
  • 2,334 Answers
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
  • Arturs Kalnins
    Arturs Kalnins Jan 10, 2009
    The top button is for chronograph function and puts the chronograph
    seconds hand in motion. The bottom button is for resetting chronograph
    seconds hand to zero.
    Do as follows:
    1) push the top button once- seconds hand starts moving,
    2) push the top button once more- seconds hand stops,
    3) push the bottom button once- seconds hand returns to zero.
    You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
    Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
    If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
    Do not forget to rate, please.
  • Arturs Kalnins
    The subdials (small ones) have very many variations, but usually they counting hours and tenths or huderedths of a second alongside with chronometer.
    If more info is needed, submit full specs of your watch(brand, model, all the numbers, etc.,)
    Hope all yhis helps to get familiar with your watch.
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
TX T3B891 INSTRUCTION MANUAL
Anyone know how to fit a new battery in a watch its a TX model number: T3B891
Jul 14, 2012 | TX Technoluxury 770 Fly-back Chronograph -...
Seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Apr 29, 2010 | Swiss Army Wenger Commando 70725 Wrist...
I need to know how to use my cl1112 Tag Heuer
Copy "ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf"" into your search engine and it will take you to a generic instruction manual for TAG watches.
This manual includes instructions for operation of your watch.
Mar 01, 2010 | Watches
How do you use the alarm in the Seiko coutoura chronograph?
You can obtain instructions from the Seiko web site "seiko.com".
Go to their web site, click on "support". The on "instruction booklets",
You can either enter the number off your watch or choose the instructions from the list.
Jan 25, 2010 | Seiko Coutura Chronograph Watch
Instruction for Lorus chronograph watch
Go to www.loruswatches.com and they have instructions there. I didn't download that translator and it still was available in english. I don't know your model number but you can do that there. Hope it helps.
Dec 27, 2008 | Bulova Chronograph Watch
Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
Oct 01, 2008 | Watches
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Sep 03, 2008 | Watches
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Sector 2653940025 Wrist Watch Logo
933 people viewed this question
Top Sector Watches Experts
staicuma
Level 1 Expert
aravind shet
aravind shet
Are you a Sector Watch Expert? Answer questions, earn points and help others
