Question about Irons
My Braun Si 3120 Optistyle Iron is leaking water from steam holes
Leaky Iron
  • 4 Answers
Scale buildup is unseating the rubber seal. Disassemble the iron. (Water filler hole part pulls directly forwards and can be pushed out from behind with a screwdriver.) Otherwise it's fairly straightforward. Clean scale off baseplate. Seal with silcone gasket before reassembly.
Posted on Sep 16, 2010
My argos steam generator iron is leaking and now does not produce steam, whats the problem and how can i resolve this problem?
tank or ports clogged: Disassembly and inspect , replace tank and seal if badly clogged or leaking. Emptying iron after each use allow heat to evaporate emaining water and help preventing clooging. Inspect valve and linkage: clean and replace as necessary.
God bless you
Jul 22, 2012 | Irons
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
Dec 27, 2010 | Krups V70 Iron
Sole plate leaking
This IS a steam iron? The iron must be hot for the steam to form. If it's not hot enough, the water is leaking thru the steam holes. Also if the channels are calsified (boiler stone has formed into the steam channels) this may happen.
Nov 04, 2009 | Tefal Irons
Water leaks out of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Nov 23, 2008 | Black & Decker Steam Xpress AS250 Iron...
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Irons Logo
548 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
