Question about Reddy Heater-30-55,000 BTU Variable
Reddy Heater R55 concerns
I have a model R55 reddy heater and recently it would not ignite. When I took the top cove off I noticed that there are 2 green wires that are not connected to anything. They look like they could be ground wires because they have eyelits on them but there is no missing screws or anyplace inside the heater body where it looks like they go. Does anyone know what these wires may be for?
    Novelist:
    Champion:
  • 224 Answers
They are grounds, and should have two screws on the burner tray to hold it from moving. On my heater this is where the grounds get attached. It gives the igniter a dedicated direct ground.
Posted on Dec 27, 2010
R55 model. runs for a while & cuts off. [1]
Dials? I assume you are speaking of the air pump adjustment screws.
How to set the pump pressure
Nov 20, 2010 | Reddy R60A Utility Heater
R55 reddy heater takes 5 seconds to fire
I SUGGEST U GO TO THE FOLLOWING WEBSITE:
http://www.reddyparts.com/
HERE U WILL FIND THE INFO U NEED.
Dec 20, 2009 | Heating & Cooling
Will not start unless top cover is off
Check that the fan is clean and unobstructed. It sounds like something may be cutting down the air flow. Or the cad eye may be faulty or dirty.
Hope this helps.
Matt
Jan 08, 2009 | Reddy Heater-30-55,000 BTU Variable
Unburned fuel coming from front nose cone when heating
in the back of the heater by the filter there should be a screw if yours is like mine screwing it in adds fuel backing it out gives you less make sure filtre is clean because if it isnt it will make it **** more fuel i took the cover off watched the ignitors and adjusted the fuel until it stoped making the jet sound and that is where i left it seems to be burning good there give it a try hope i helped
Jan 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy R55 Wont Ignite
Fuel not a problem. Wrong pressure definitely a problem. Click here for instructions on setting the pressure.
Nov 20, 2008 | Reddy R70ET Utility Heater
Replacing rotor on Readdy Heater
Remove top shell. Remove cover. Remove filters. Remove filter base. Then it should pull out. Check clearance on new rotor .003/.004 checked with feeler gage. Reinstall in reverse order. Reset air pressure. Good luck.
Jan 15, 2008 | Reddy R70ET Utility Heater
Reddy Heater-30-55,000 BTU Variable Logo
115 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
