Question about Philips Magnavox 42MF521D/37 Television
Mykids were playing with their - Philips Magnavox 42MF521D/37 Television
Mykids were playing with their Wii and in the middle of the game thepicture disappeared and flashed a white screen then a black screen andthen immediately went to this white/black/white vertical stripe down the center.
I have read that this may be a bad IC driver. Where is that located on the TV?
Don't let the kids near the TV.
Posted on Jan 10, 2009
My Nintendo 64 when I was in the middle of a game it froze and the screen went all black and then it went to the tv screen saying no signal then.
Well one time I had this problem with my Nintendo 64 console when I was in the middle of playing perfect dark the screen had froze went black and then it went to saying no signal on the tv screen. The console did not over heat to cause this problem. I thought that it had died on me but I had tried a new expansion pack and it was fine after that. SOmetimes the expansion packs can blank out in the middle of a game play they can die without a warning then. Or it can say expansion pack needed or it will give the white flash that it is turning on but nothing happens after that then.
Mar 22, 2016 | Nintendo 64 Console
Wii only in black&white
This is a common problem and it is not specific to Wii Fit Plus, it is a TV setup issue.
Access your TV's menu screen and be sure that your TV screen is expecting input from "AV" or "Video". If you have "S-Video" selected, this is the cause of why your Wii is playing black and white.
Feb 25, 2011 | Nintendo Wii Fit Plus for Wii
Wii plays in black and white
Feb 15, 2011 | Nintendo Wii Console
Color problem
The only way to fix this issue is by getting the defective Wii repaired.
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform: http://www.nintendo.com/consumer/webform.jsp
Setup a Repair Online:
http://www.nintendo.com/consumer/repair/repair_charts_wii.jsp
Nov 20, 2009 | Nintendo Wii Console
Wii plays in black and white.
Check if the tv has different types of AV settings, as this affects whether the wii plays in black and white or colour.
Aug 04, 2009 | Nintendo Wii Console
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Vertical lines down center of Plasma TV
Because of the complexity of these sets, the fault can be much more than just a bad IC. These sets are serviced at the board level. After changing the board, calibration is done as necessary.
The fault may be in the matrix power driver output area, or in the plasma screen back-plane layer itself. This has to be determined by the process of elimination.
I can tell you in advance that this will not be a low cost repair.
Jerry G.
Jan 10, 2009 | Philips Magnavox 42MF521D/37 Television
Wii gone bad?
check your connection to the tv. are you using the rca jacks? is the rca input on tv "loose"?
Nov 06, 2008 | Nintendo Wii Console
Wii video is black and white
Possibly you've plugged the video into the component (RGB) portion of the input - this calls for 3 connectors (Red, Blue, & Green) and if you only plug one in from a composite it comes out grayscale. If you only have one video lead (yellow connector) make sure it is going to a composite connection which should also be yellow. Otherwise, more info is needed about your connections.
Nov 02, 2008 | Nintendo Wii Console
LED turns green, but console doesn't start up
hum........ that is weird I'm not really sure how to fix that. But make sure all the cable from the wii are plugged in properly. For example: the red, yellow and white cables may look like they are plugged in but sometimes you have to push them in really hard to get them to work.
My wii does that sometimes in the middle of a game it just goes black so I just have to walk up to the TV and make sure they are im properly.
May 17, 2008 | Nintendo Wii Console
Philips Magnavox 42MF521D/37 Television Logo
155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
