Question about Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion Entertainment PC - scrollbar on mouse pad not working
The little scrollbar on my mouse pad is not working. I can use the mouse pad, but not that feature.
  • horselover10 Feb 12, 2009
    After installing updates on my computer my scrollbar on the mousepad also stopped working. It'd be great if someone could tell me how to fix it.
I think I can help you. I need to know what kind of mouse driver you are using. To find out click on the control panel, click on mouse properties, click on device settings. Under devices it should show Enabled/Name/Port. Under Enabled it should say Yes. Under Name should give the name of the device being used and under Port it may or may not show anything. Ex. Yes /Synaptic TouchPad V7.2 / Port/2. If this is what yours shows, double click on the highlighted device and a menu will come up. From there you can reactivate your scrollbar. If yours does not show a device in the list, sometimes it will show where to go to download the device in the bottom righthand corner. EX:(www.synaptics.com) If not, you will have to find the name of your device. Hope this helps. Tim
Posted on Jan 17, 2009
  • Maja Lange Nov 02, 2011
    Hi. I have the same problem, and I've followed your instructions - right up to the 'activate' part. When I try to select 'Activate vertical scroll', no dot appears in the little selection circle (and it doesn't make the scroll bar work). The text in the box below the activation box changes (to sth about horisontal scrolling), however, so there IS some sort of reaction. Just not the right one, So what's going on? - Sincerely, Maja.
    Hi Tim. I have the same problem, and I've followed your instructions - right up to the point of activating. When I try to select 'Activate vertical scroll', no dot appears in the little selection circle(and it doesn't make the scroll bar work). There's no dot in the deactivation circle, either.The text in the box below the activation box changes, however (to sth about horisontal scrolling), so there IS some sort of reaction. Just not the desired one. So what's going on? - Sincerely, Maja
  • 51 Answers
Go to HP.com and download the driver for the Synaptics Touchpad and install it.
Posted on Jan 10, 2009
2 Suggested Answers
kram26
  • 544 Answers
SOURCE: HP Pavilion Entertainment PC - scrollbar on mouse pad not working
hi there.
maybe your mouse is not comaptibel with the system of your laptop or you need the disk driver to install the mouse to work properly?
or your mouse is already damage and need to replace try to change it with a new one.
Posted on Feb 15, 2009
Scroll bar wont work
This the one on the trackpad?
Make sure the trackpad application (not just the driver) is installed and running that came with the HP (probably visable as an icon near the clock).
The scrollbar is not a feature of windows (unlike normal mouse operation) and it requires the HP mouse trackpad app to be running.
Dec 21, 2013 | HP Pavilion DV9740US Laptop
How do I disable screen rotation on a HP Pavilion dv7. I don't know exactly what causes the screen to rotate, but it always happens when I'm typing something. It is hard to get the mouse to...
NO OS stated
no full model stated, DV7-nnnn, what is the nnnn?
NO OS stated, this XP? the virus magnet?
sounds like the post is how to get the mouse pad on the top
of the laptop working right, that it?
first use any USB mouse made, plug it in, get it to work
then fix the PC using a REAL MOUSE.
the mouse pads fail because the driver, is missing or wrong.
NO OS stated, at all so how can any one help you lacking such a key fact.
but if you did use the mouse external USB.
and did go to device manager using the mouse
and did change the driver on the MOUSE pad, to the one
that is on HP site, it would work (if not damaged)
no full model stated so cant show exact pages
see here why DV7 means Zero">
https://support.hp.com/us-en/products/laptops/pavilion-notebooks
29 models made.
lets say you said - dash 1000.
id say
go here
then you said, windows 7-32bit.
and id show this. (show at tell , like kids do)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv7-1000-entertainment-notebook-pc-series/3744231
then find the mouse driver,
HP has the here. click mouse
sp45623.exe (27.6 MB)
my best guess, lacking all facts but DV7 terse
Dec 14, 2017 | HP Computers & Internet
Hp pavillion tx2000 entertainment notebook pc. initial o/s vista home premium. Problem with cursor drags automatically. whole system scan with kaspersky antivirus. problem not solved. o/s changed to...
You meant the built in mouse pad fails.
why not use wired USB mouse, now, and end the pain ,
then with a working mouse , get the HP driver from HP
and install it from HP. for W7. (luck)
at HP, fixyah is not HP, not at all..
that will work, if not driver issue, then buy a new pad. oops none are sold new.
after 10 years. so that leaves what, used pads sold on ebay..'
HP dot com. your support page. (seems to be collapsing from age)10years old it does. by hp rules.
even the tx2500 series is 10 years old now.
https://support.hp.com/us-en/product/HP-Pavilion-tx2000-Entertainment-Notebook-PC-series/3650975
does your service tag show tx2000 , that is series
not telling the service tag number gets you wrong facts.
wrong drivers, so next time show the full model
try the support assistant there.?
here are the full list of tx2000 series PC
see ,its not just one PC, we need the full model p/n to answer
with any accuracy at all.
http://partsurfer.hp.com/WSearch.aspx?Wchar=Y&searchText=tx2000#
there is no guarantee at all any w7 driver exist. for your mouse pad but many times the Vista version will work
you lost that now, i you dont have the install disks from HP.
or the pad is simply bad.
we have tools here to scan your pad chips to see the makers
name and then get driver from them direct. after HP drops support.
Jan 24, 2018 | HP Pavilion TX2000Z Notebook
How do i unlock the hardware of keyboard? its lock, cant press it anything. im typing on screen laptop. its hp pavilion entertainment pc.
there is a button just above the track-pad (mouse controller) that normally only dissables the mouse but it might work for this too.
Mar 07, 2011 | HP Computers & Internet
My scroll up and down is not working
if you are talking about the mouse scroll then i recommend that you have to replace your mouse cause or clean the mouse.
Thanks
Aug 14, 2009 | HP Pavilion dv5-1125nr Notebook
Touchpad scrollbar feature is disabled on my laptop
Hi there.
The keyboard toggle to reactivate the touchpad is Fn - F7
Please post back if the problem persists.
Good luck and thanks for using FixYa!!
May 24, 2009 | HP Pavilion DV9740US Laptop
Laptop sound not working
troubleshoot for a disconnected wire right below the mouse pad or under the speaker panel. I went through the same problem... it was a disconnection problem. I fixed it myself and never tore a computer apart before. It works great now!
May 18, 2009 | HP Pavilion dv6000t Notebook
HP Pavilion tx 2000 touchpad problems
Ok,The setting for the touch pad are not in the mouse settings,They are in the pen and input settings.
Just go to the control panel and select Pen and Input setting and adjust as needed.
Also with Vista,Windows tries to control everything,so you may need to un install the mouse drivers and allow windows to take control,It will not prevent the touch pad from working,It just stops it from being controlled by the touch pad driver and the windows mouse driver ar the same time.
May 07, 2009 | HP Pavilion TX2000Z Notebook
hi there.
Feb 14, 2009 | HP Pavilion dv6000z Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
9,527 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
