Question about Cozy (W352E) Heater
Natural to LP conversion Cozy CF503C
I would like to know how to convert my Cozy CF503C Wall Furnace from Natural to LP. I was going to change the orfice in the gas valve, but then saw a sticker on the valve that reads do not convert. So what do I need to do to safely convert heater into propane.
  • royalball Jan 10, 2009
    Would it be safe to convert this by changing the gas valve if so do you know what gas valve would be recommended
    I would like to safely convert my Cozy CF503C counterflow wall furnace from Nat gas to LP. I was going to change the orfice, but noticed a sticker on it that read DO NOT CONVERT. So I'm wondering what is the safe way to convert this furnace. Do I need to but a new gas valve, if so what valve is recommended, is there anything else I need to change to safely convert this. Thanks
  • 470 Answers
You need a converter on it,, try this sites,, there is an instruction on how you do it and guide  http://www.latestbuy.com.au/convert-vinyl-cassette-to-cd.html
Posted on Jan 10, 2009
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 22, 2009
    RULE OF THUMB: When it comes to combustible systems, believe the
    original equipment manufacturer. If they tell you not to convert it,
    dont.
    I sent you specifications for your counterflow wall furnace, which
    contain the advice to contact the wholesaler from whom the unit was
    purchased for further information.
    Genius:
  • 1,239 Answers
Hi
There usually is a metering device in gas valves for accepting natural gas and propane. You need to find out if yours has that ability or just purchase a new one which is inexpensive and probably the right way to go and install the new valve. That is the only adjustment needed
If they don't offer a conversion kit it's game over! It cannot be legally converted. If you go ahead and alter the appliance and somebody is hurt or property is damaged by it, you will be liable, and insurance companies will not cover you for losses.
You will need to contact the manufacturer to find out two things...Is it convertable, and what parts etc. are needed to do that. If they will provide both of these things, you are away to the races! Install the conversion kit and new rating plate, and you are done.
By the way...Most manufacturers supply the units from the factory set up for NG and provide propane conversion kits. There are very few appliances that can not be converted from propane back to NG. There ARE a few, but not very many!
    Scholar:
  • 91 Answers
Change out the gas flow orifice size to propane.
Purchase a new one which is inexpensive and probably the right way to go and install the new valve. That is the only adjustment needed.
Thanks.
    Brigadier General:
  • 5,158 Answers
If it says do not convert i would strongly advise that you don't as a safefty issue. gas leaks can be very disastrous.
Robert
    Scholar:
  • 98 Answers
You need to find a brand that does allow for the conversion....As you probably noticed the orifice is removable on your model.. The reason for the sticker stating not to convert is because of the liability issues that the mfr. doesnt want responsibilty for....The safest way is to call the gas co. Even if you have to tell a little white lie that you suspect it might have leak...They will come out for free ..At this point befriend the gas man and pick his brain for the answers you need....I myself have converted my LP barbque to natural and it also had the same sticker.... So it is possible...Good Luck
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
A plumbers license. Do not attempt. Can you say go boom. Not the answer you wanted and not to say it can't be done but can you say "DO NOT TRY THIS AT HOME". If you found this worthy a fixya, please rate God bless.
  • bob collins
    bob collins Jan 10, 2009
  • 19,396 Answers
You need to replace the gas valves for ones that accept propane, and also to replace the meter.
The job is quite complicate, I can do repair many appliances, but I would need to call a technician to do a conversion, there are also many safety issues involved.
See the link below with more instructions.
Converting a propane heater to natural gas
Here is also one of our professional technicians
, it may take time to get the answer, as he is offline now.
Use the ask me to get guidance.
    Scholar:
  • 160 Answers
I would suggest you not to convert it as it may be dangerous because such coverting and altering may result in leakage problems further.
How to change from natural gas to LP
Brian, You usually have to purchase a conversion kit for your make and model #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stove conversion natural gas to Lp
Range Conversion
How to Convert Natural Gas To Propane DoItYourself com
Converting LPG and Natural Gas Appliances
May 12, 2016 | Kitchen Ranges
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
How to adjust the burner flame , it is blue and it is going down , its a cozy single wall furnace
gas pressure should be 3.5 on natural gas and 10 on propane, also make sure burner is clean.
Feb 26, 2015 | Cozy Heating & Cooling
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
I bought a used Goodman furnace. The person ran LP to it and I want to run natural gas. What do I need to do? Is there a conversion I need to buy?
yes i will need to be converted.the gas valve and the gas Orphic will need to be changed.you will need to get this from Goodman
Oct 10, 2009 | Heating & Cooling
Propane conversion for cozy model CF503C
try national energy for a conversion kit they should be able to help or the will know some one who can
Jan 10, 2009 | Cozy CFR Utility Heater
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Convert to LP?
If it is possible, then the orifice has to be changed. The regulator may need to be changed as well. I am a certified LP technician for recreational vehicles, but I don't know enough about this particular appliance to say for sure if it can be converted. The best thing is to contact Miele directly, but this sort of conversion always requires a different orifice. Note that propane, butane, and natural gas are all forms of LP (Liquified petroleum), so conversion between the 3 is usually possible
Oct 15, 2007 | Miele 35 in. KM326G Gas Cooktop
Cozy (W352E) Heater Logo
168 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
