Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant connect to xbox live with my wireless network adapter
It wont work! I turn my Xbox on and It shows red connection. When its green that means it should be working. I connected it to our network and it still wont work. Can someone help?
Anonymous
Level 2:
  • Expert 142 Answers
  • Posted on Jan 11, 2009
Anonymous
Expert
Level 2:
Answers
142
Questions
0
Helped
73621
Points
285
1 Related Answer
Anonymous
  • 60 Answers
  • Posted on May 20, 2010
SOURCE: Wireless Network Adapter Xbox 360 (SKWIFIX360): My xbox 360 wireless adapter won't stop flashing g...
Make that your wireless router is successfully configured to your network.
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
tip
How to connect to Xbox Live wirelessly
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Trying to connect to x box live. just bought the
Okay so here we go!
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay so here we go!
1helpful
Xbox live on netopia router
Okay so here we go!
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay so here we go!
Hope this tip helps :).
Need help connecting xbox live to the internet, have the wireless router but nothing is successful
Okay so here we go!
I just bought xbox live wireless and i have a westell 6100 router
Okay so here we go!
Having problems hucking up to xbox live
Okay so here we go!
Xbox network adapter wont connect to a network.
go to youtube type in how to hookup wireless internet to xbox 360 a guy will show you step by step way easy..
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
