Bad Pool Caller message??
I got a blue screen with the message that windows was being shut down and Bad Pool Caller. The message goes on to suggest removing anything new however nothing new has been installed. It ends with the message ''beginning dump of physical memory.''
When rebooting the screen returns but automatically shuts the computer down after a short time. I have a Dell Inspiron/Windows XP
Any help is much appreciated!!
  • Andrew Podner May 11, 2010
    can you boot into safe mode (F8 when when windows begins to start up)
    President:
  • 2,559 Answers
BAD_POOL_CALLER is a stop error message that is caused because of problems with the memory management.
There is a list of more than thirty such causes that can give you this error message. If the stop error is consistent every time the system is rebooted, the following method will be effective in solving the problem:
* The hardware and RAM should be checked initially.
* Boot the system once again using the OS setup CD, or use a boot setup that has a GUI like BartPE.
* With RunScanner it is possible to use a memory test tool.
* Select a single account
* If all the accounts open then the system registry hive might be the problem.
* Locate the hive damaged and rename it, do not delete it.
* Create another hive from the backup or from the restore point.
* Initially uses the latest one and keep checking the restore points that come later.
* Avoiding harvesting any replacement hives from the hard drive booted Windows.
* After which compare the hives for differences.
This is one of the ways of fixing BAD_POOL_CALLER errors. Another method is to reinstall the OS but occasionally shows a disk read error or an error on the same lines. Switching the computer off for a minute or more and then switching it on can solve it since the error is only a slight glitch in the system operation.
The BAD_POOL_CALLER is seen for the first time after installing a hardware or software it is recommended that the computer be restarted. If it doesn’t solve the problem, the installation of the hardware or software should be checked for corrections. If the problem persists the installed hardware and software should be disabled, and the BIOS memory options like caching or shadowing should be disabled too.
The safe mode can be used as well to remove or stop components.
To enable the safe mode just press F8 when the machine is being restarted and select it from the Advance Startup options and correct the problem. The installation of the graphics card is another reason the BAD_POOL_CALLER error shows up. A simple reinstallation of the driver can solve the problem.
Microsoft has also acknowledged that the BAD_POOL_CALLER Stop 0xC2 error pops up when trying to print a document that contains a corrupt font.
A hot fix is available at www.support.microsoft.com
Posted on Jan 10, 2009
Hello i have an HP windows 7 i turned it on and it goes to blue hp screen and freezes up
A blue screen error usually comes up on Windows 7 when there is a serious hardware or software issue that may be causing Windows to Shut Down unexpectedly. At times, a message may also come up on your screen saying "Windows has been shut down to prevent damage to your computer."
To troubleshoot this issue, you may need to try out multiple troubleshooting options to detect whether the issue is with your hardware or software and to resolve the same as per the recommended procedure.
To know more about your troubleshooting options to get rid of blue screen error, you need to refer to the following Microsoft and HP support pages:
http://windows.microsoft.com/en-in/windows7/resolving-stop-blue-screen-errors-in-windows-7
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00372711#N182
The above troubleshooting steps may also help you to resolve the freezing issue. If they don't, please let us know so that we can suggest you additional troubleshooting options for the same.
GuruAid.com
Jul 13, 2014 | Computers & Internet
I did complete install to windows 7. Now when I shut down, closrs windows,then blue screen comes up (can't tell what it says,goes to fast to read all)
Disconnect printer,/scanner, camera, USB stick connected to the computer. Try to start it in safe mode by hitting F8 key at the start-up.
Jul 08, 2013 | Computers & Internet
MY LAPTOP GOES TO THIS BLUE SCREEN THEN SHUTS DOWN WHY DOES IT DO THIS
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 14, 2012 | Toshiba Computers & Internet
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
Blue Sreen Error
I strongly suspect bad ram when any computer displays that message.
Apr 25, 2008 | Compaq Evo N610C Notebook
Blue screen at Microsoft second security package
Comment by ceryac, posted on Jun 26, 2008 This morning I have started getting the error message Bad Pool Header after my computer has been on line for about 25-30 minutes. RegCure said it can fix Blue Screen errors but it does not fix this.I have no idea why or what to do to fix it.
Regards
Ceryac
Apr 05, 2008 | Xterasys XN-2423G (XN2423G) Wireless...
Windows XP: Blue Screen of Death
Hi are you connecting the usb devices b4 or after windows has started? what version of windows r u running?
Do the usb devices come with their own driversand software?
Dec 18, 2007 | Dell INSPIRON 6000 CENTRINO...
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Computers & Internet Logo
2,372 people viewed this question
David Payne
David Payne
