Question about Xerox Office Equipment & Supplies
  • 2,072 Answers
The C20 does not have a main board capable of adding a NIC. It has to be a minimum of am M20, M20i has fax capabilities.
Posted on Jan 10, 2009
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
Unable to use upper feeder on CopyCentre C20
Turn the machine off. Disconnect the white cable on the back of the machine. Turn the machine back on let it come to ready.
Turn the machine back off, plug the feeder back on and turn the machine back on.
The machine seems to forget it has the feeder from time to time.
It has to boot up with it unplugged to reset.
Nov 09, 2010 | Xerox CopyCentre C20 Black and White...
Password for the Copycentre C20
Try 0000. That is quite often the default.
Nov 21, 2009 | Xerox CopyCentre C20 Black and White...
Copycentre c20 has open heat error message. How do I replace fuser unit?
The fuser unit for this machine can only be installed by a technician as the fuser unit itself is not for sale to consumers.
Nov 19, 2009 | Xerox CopyCentre C20 Black and White...
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
I need Know, How enter to service mode
Press,,,,, Menu #1934 . What you may want to try first is to do what is called the Shading adjustment. That calibrates the scanner.
It would be found in the maintenance menu after you enter diagnostics.
You must place 5 pieces of white paper on the glass before you perform the adjustment.
There really is no way to increase the amount of toner concentration on that machine. You may very well have a defective ink cartridge. That is not uncommon on the C20. There is a metering blade in the toner cartridge that often times does not allow enough ink to be applied to the toner roller.
May 13, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
u can find manual for this copier at the link below:
Jan 10, 2009 | Xerox CopyCentre C20 Black and White...
CopyCentre C20 Toner Low Stays On
ave you tried shaking the cartridge vigorously from side to side?
The ink may be compacted in one end of the cartridge from storage.
Jun 06, 2008 | Xerox CopyCentre C20 Black and White...
89 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
