Question about Definitive SuperCube Reference Subwoofer Speaker
I can't turn on my Definitive Technology Supercube Reference Subwoofer. I just received it and plugged it in. Nothing happened.
  • 19,396 Answers
Test it on a different socket, and ensure that the cube audio cable at the back is properly connected.
Read the first pages of the user manual to find connections diagrams and instructions.
If the unit does not start at all, then it is defective. In that case have it replaced.
Posted on Jan 10, 2009
    Genius:
  • 1,199 Answers
Make sure the sub is hooked up to the sub jack in back of unit! make sure sub is turned up! make sure signel is going out to sub from the amp!
    Sergeant:
    Novelist:
  • 326 Answers
Its a cable problem just get it checked and replaced. its a common problem in such device.
My definitive technology pro cinema 600 sub stopped working
theres a setting is on the subwoofer itself, not the AVR. It usually has 3 positions: On, Auto, Off. Auto allows the sub to "sleep" when it's not being used, and to power back up fully when it senses a signal. Maybe change to On position which would bypass that auto mode
May 07, 2017 | Definitive Audio Players & Recorders
The subwoofer by DT ProCinema 600 doesn't work
I had the same problem when I wanted to swap my PCicon1.png 1000 for the PC 2000. The later interfered with my view on the tv. What I did was raise the tv on a couple of pieces of MDF. I painted the edges of the MDF to match the tv stand. Looks great - is very solid as far as support for the tv - and allowed me to get the PC 2000smile.gif
Nov 04, 2014 | Definitive Technology ProCinema 600 black
Where to buy replacment speakers
This is a specialty speaker so I do not recommend looking anywhere but with definitive for this. Their products are like high performance sport car assessories, where they are "tuned" to work as a cohesive system. If you really don't want to go that route, start with partsexpress.com.
May 18, 2014 | Definitive Technology SuperCube Reference...
Nr 1402 receiver marantz
You need to make sure the sub is plugged into the sub pre out connector. Not the the sub out. You might also have to go to the user menu and tell the unit that you are using a sub.
Jun 06, 2012 | Marantz NR 1402 AV receiver - Black
My subwwofer does not seem t power on .....it is also not picking up a signal...... can you help with this
Hi slikrik
Please check your external connections, power if everything is ok then.. First please confirm when did you purchased this Active sub., This sub system is having 5years warrantee on Speaker and 3year on Amplifier. Hence, if you are the due date please give it for free checkup and replacement for parts.
-sai kumar
Dec 28, 2010 | Definitive SuperCube II 8" 1250-Watt...
My Definitive Technology Supercube ii subwoofer is not powering on. I've checked the electrical outlet so it's not that. I suspect it might be a problem with my subwoofer cable but I don't want to take...
Unfortunately, the most common problem with powered sub woofers, including definitive technology, is that the capacitors inside dry out. To check the speaker, you can connect any line level audio source (like an mp3 player) to the speaker and see if it comes on. If it does come on, then you will know the speaker is ok. If not, then the speaker will need servicing. Powered sub woofers are not usually a DIY project.
Dec 11, 2017 | Definitive SuperCube Reference Subwoofer...
Definitive Pro-Sub 1000 subwoofer replacement fuse.
Fit a 3 or 2.5 anything lower, if you can get away with it, but nothing higher.
However the chances are that it blew due to an overload, often caused by a shorted semi-conductor acting like it was a piece of wire. So even fitting a smaller one and it blowing again doesn't mean it's due to the rating.
Jun 25, 2010 | Definitive ProSub 1000 Subwoofer Speaker
I have a Sony Receiver STR DA2400ES with a Definitive Technology ProSub 800 Subwoofer. Lately, I noticed that the subwoofer isn't working. I did a system test and it didn't work. The power light on the...
Prove it's alive by feeding it the signal from any other source, like Left or Right Tape Out. Use FM as the source to keep things simple. Then we can move forward with analyzing the correct failing unit.
Dec 28, 2009 | Audio Players & Recorders
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
Placement of definitive supercube 2
Make shure your crossover on the amp is set at 80hz. If closer to side walls you will get more response but may be muddy. Make sure it goes low enough to comliment the klipchs.
GOOD LUCK
BIGRED
Apr 10, 2008 | Definitive SubAmp 600 Amplifier
Definitive SuperCube Reference Subwoofer Speaker Logo
176 people viewed this question
Top Definitive Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob
Rob
Are you a Definitive Audio Player and Recorder Expert? Answer questions, earn points and help others
