Question about Master Heaters MASTER HONDA POWERED GENERATOR Circuit breakers-2500 rated watts 120 VAC/20
1995 blazer "1995 blazer ".code po305 misfires on cly #5 reset code idles rough code reads same changed wires plug cap rotor can anybody suggest anything to do .
    Problem Solver:
  • 3 Answers
I am just a backyard mechanic but since the code says #5 misfire detected, and you've changed the plug, wire, rotor, and cap; something that is possible, besides a computer or sensor problem, is the a piece of carbon is coming loose and is heating up and the sensor is picking this up as the spark. Don't know how to test anything else. Maybe this will help reed
Posted on Jan 16, 2009
I HAVE A 2006 BMW Z4 3.0I ROUGH IDLE.. SET CODE # PO305 # 5 MISFIRE..SO I REPLACED THE COIL AND PLUG WITH A NEW SET. STILL ROUGH IDLE BUT NOW WHEN STOPPED AT A RED LIGHT WILL DIE.. CODE GONE NOW BUT??
code p 0305 is the no 5 cylinder misfire and included in the list of causes are plugs and wires but unfortunately also in the list of causes are== injector, injector connections and wiring and this is the most common area of the misfire and not the plugs or ignition circuit
pull and check no 5 injector and place it in another cylinder and see if the fault moves to the new cylinder
if it doesn't move it is in the wiring and control
if it does move , replace the injector
Jun 25, 2017 | BMW Cars & Trucks
2001 Blazer rough idle and misfire cylinder 2 code
misfire codes are most often generated by faulty injectors and not what you have replaced
the misfire can be from blocked injector tip, failing injector wiring/signal and low fuel pressure
move the injector for 2 to another cylinder and see if the code moves as well to the next cylinder ( replace injector)
if not check wiring or ECM for problems
Jan 30, 2016 | 2001 Chevrolet Blazer
Cylinder 3 misfire code 73 honda civic
i would check egr valve and check to see if working this will cause misfire codes that you have had /swap sparkplug with another cylinder and see if problem now at another cylinder could be bad spark plug as cause
Dec 19, 2013 | 2005 Honda Civic
97 chevy blazer rough idling problem? help?
It is hardly ever the spark plug or only the spark plug - generally for some reason there is a weak or lost spark and the reason must be found and rectified by carefully checking and then replacing any components found to be edfective - plug wires, coil, distributor cap, rotor (if fitted), wiring, connections and could conceivably even be the ECU. Perhaps the misfire is due to injector trouble...
Sometimes a fault with persist even after it has been "cured" until the fault code is erased with diagnostic equipment.
Jun 26, 2017 | Chevrolet Blazer Cars & Trucks
Hello I have a 1999 Chevy Blazer with a 4.3L I keep getting the code Multiple misfire or misfire cyl 5. I have replaced the crank sensor, cam sensor, ignition module, map sensor, injectors, fuel filter,...
Make sure plugs are gapped correctly and coil pack is good . If can't feel it missing could be a false code generated by computer . Hope this helps
Dec 19, 2017 | 1999 Chevrolet Blazer
I have a 1996 crown vic i need to know these touble codes po305 po304
P0304 means that cylinder 4 has a misfire and P0305 is a cylinder 5 misfire. What this means is you may have bad spark plugs, or bad plug wires, or you may need to replace your distributor cap and rotor. I would start with plugs and wires.
Oct 21, 2010 | 1996 Ford Crown Victoria
Code p0300 coming up random cylinder misfire already changed wires had cylinder 5 misfire .should i replace coil
If you already replaced the wires, I would suggest replacing the plugs, distributor cap and rotor. They are also very important parts of the spark. Fuel injector problems can also cause misfires.
May 19, 2010 | 2001 Chevrolet Blazer
My jeep idles rough but on acceleration is powerful as can be.i have changed plugs wires cap rotor and have scanned it with only misfire codes
hola como puedo saber cual es el problema con mi 96 grancheerokie cada vez que acelero despues de 1500 rpm el motor pierde fuerza y avienta explociones por el throurolbody ya cambie los sparkplugs,cables, rotor, cap y el motor ya esta a tiempo herreravazquez2006@yahoo.com
Dec 14, 2009 | 1997 Jeep Grand Cherokee
Master Heaters MASTER HONDA POWERED GENERATOR Circuit breakers-2500 rated watts 120 VAC/20 Logo
110 people viewed this question
Top Master Heaters Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Master Heaters Electrical Supply Expert? Answer questions, earn points and help others
