Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 has a shadowed picture.
The RGB on the television is not aligning. I ran the auto convergence and the manual convergence several times. The image got better, but the center of the TV looks pretty good but not perfect while the image gets more distorted as is got further to the edges. I adjust the RGB lenses and the picture got much better but is still distorted. When adjusting the RGB lenses is seem like more of a focus than an alignment. If I adjust the lenses so the center looks good, the image on the bottom left of the screen is shadowing slightly downwards and to the left, while the image on the bottom right of the screen is shadowing slightly upwards and to the right. The top of the television does the same thing as the bottom but not as much shadowing. I have a computer hooked up to my TV so I looked on-line and found color adjustment screens to see if it would help with adjusting. This is when I noticed what was shadowing. The red is shadowing downwards on the bottom left of the screen while the blue is shadowing upwards on the bottom right of the screen and green is just in between, this is the same type of issue left to right. Adjusting with black and white bars it is impossible to adjust it to a clean black to white line. What I mean is, it’s more like the white fades into red, yellow, green, cyan, blue to black. I’ve checked all of the fuses and carious if an IC went bad or if I need to replace a board. Any help will be much appreciated… oh… sorry for the essay.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, this normally indicates failure of the convergence circuitry, 2 STK ICs involved, a couple of resistors, perhaps some pico fuses and alignment thereafter. Are you considering a DIY (do-it-yourself) repair? If yes, pls post back.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 10, 2009
    Scholar:
  • 160 Answers
In that case if the manual tuning is not helping much u will have to replace the convergence ic on the board.
    Sergeant:
    Novelist:
  • 326 Answers
The convergence ic may be at its last stage and needs replacement.just get it replaced and check out.
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Showing irregular colors are red green and yellow and doubles
Tv have a problems known as a picture convergence problems,it is dead.Tv have colors R,G,B lines are mis alignments in pictures,have colors shadows pictures or 3D picture look alike?Yes,than the tv convergence board it dead,tv must require replacement on the tv convergence board like 2 STK conconvergence ICS and some or all of it resistors too,to fixed the tv convergence board to solved tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Jul 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Question - What would cause the colors to be off..meaning..it looks almost 3D and with widescreen shows the black on the top and bottow bows into the main area of the screen. Any ideas?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.The tv convergence board must be replace all these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Dec 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY TV WENT BLURRY AND DOUBLE..WHAT SHOULD I DO?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require replacing,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shadow effect on picture. Picture is fine but there is a red shadow tint to everything (basically everything is written twice, but not in the same spot)
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model R52Wh74 RCA and we have blue color all on the screen
Have you tried to do auto convergence and see if that helps? If not try manual convergence adjustment
Jun 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca look like 3d picture
You have a convergence problem. The Red and Blue are out of convergence meaning they are out of synch, causing shadows. There should be an Auto convergence option either on the television or through the menu options on the remote. If this doesn't fix your problem, then there's a manual convergence option. Should that fail, a service call is in order. Best of luck!
Greg
May 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
It sounds as if you need convergence circuit repair and re-alignment
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken TV
you will need a convergence amp board or a convergence power supply board depending on wether its one color out of alignment or all of them. Let me know what color or colors are out of alignment and I can help you out with board selection.
Jun 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
