Is there any on how to stop the strong fan clicking sound when it spinning ? it is as if the fan it touching something inside. it can get quite at times when i give it a good hit, but will come back to its noisiness quickly.
SOURCE: Can't insert CD into Dell Studio 17 - ejects!
There are small plastic drive gears that respond to the drivebelt. These gears are very fragile and may have come out of syncronization.
Testimonial: "Responded in seconds with useful info."
SOURCE: When the fan comes on it sounds like it is hitting
no you have to replace the fan.
if you want to know procedure for fan cleaning contact my mail id [email protected]
SOURCE: dell 9300 power up issues
The issue seems with with the mainboard please get it checked.
Thanks
SOURCE: Dell Studio 1737's power pack makes a shrieking, humming noise
I would stop using the adapter immediately. It could be about to blow. When one of these blows, you can get smoke, sparks and fire. You don't want that to happen when you are not around. Further you don't want to have a voltage spike from the adapter to *********** board. You can buy a new adapter at Walmart or whereever. Just be sure that it supports Dell computers. Dell uses a third pin frequently. Check the voltage and amperage of your current adapter. You should see something like 19V and 3 Amps. Make sure that your replacement adapter works within those rages.
You can also buy an exact match from Dell or ebay.
Expect a good Universal adapter that you buy at Walmart to be in the range of 50-100.
The good thing about a universal adapter is that you can use it on another notebook later.
SOURCE: how do I eject a
If the physical eject button is not working try going to:
Start-> Computer -> Right click on your Disk Drive and chooed Eject
If that wont work:
Shut the computer down, Press F2 on the DELL logo Welcome Screen and then try the eject button on the Disk Drive
If that doesn't work:
Try finding a paper clip and try if you can reach the Disk inside to push or pull it out.
You would need to call DELL so they can send a technician to have the Slot drive replaced. :(
Hope this helps!
Thanks Dana, I may have solved it just now, I opened the bottom part of the leptop, loosen up the upper plastic cover of the fan and the noise stoped, so I input small sheet of paper to make a bigger gap between the fan and the cover on top of it, after closing it all back it seems fine now.
