What format is the drive
In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space. The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files.
Purchase a large capacity USB external hard disk drive from a reputable vendor. Make sure that the hard disk drive is at least 100 GB. Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive. Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E." Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete. Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard. Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window. Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes.
File transfer software http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces. Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
SOURCE: I've a kingston flash drive of 4 GB when I try to
With the device connected ...
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK /F m:
where 'm' is the drive-letter assigned to the Kingston.
When the "check-disk" completes, Windows will remove the "read-only" flag.
SOURCE: i have a kingston 16
Is the drive not seen on any computer or laptop you have tried it in? If it works on other computers / laptops then the issue is with your laptop. If it fails to be recognised on other computers, then there is a chance it has failed.
Also, if you are using any emulation / copy software such as Alcohol or Daemon tools, there is a file called sptd.sys, which can cause this issue. Before advising that you delete or remove this, can you try the usb drive in another computer and indicate which version of windows you are using?
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If it turns out that the files are indeed corrupted, there are several free recovery programs you can try.
http://www.easeus.com/resource/drive/usb-flash-drive.htm
Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
