Question about Dell Inspiron 1525 Notebook
Dvd player won't open
My dvd drawer won't open on my inspiron 1525. The little black cover comes off the side of the computer and won't stay on.
  • janicm Jan 22, 2009
    CD drive won't open and the the drive is not listed wih the array of drives and storage devices lisred under "My Computer". When starting up the computer an error message pops up saying that "The device in the system modular bay cannot be identified". The error message instructed me to push in on the CD drive to re-seat it and then shut down and restart. Did no good. I finally called Dell support. They had me check a variety of things but could not determine via the phone if the CD drive is bad or if the motherboard is bad. (The CD drive plugs into the motherboard.) The computer is 7 months old and still under warrenty so they are sending a box for me to ship it to a repair site. Disgusting! The motherboard was replaced in August due to a bad ethernet connection.
  • Efren Javier
    Efren Javier May 11, 2010
    give the full details
  • 88 Answers
Start the system and keep tapping the F2 key when you see the Blue Dell logo. Once you are on the BIOS screen, try to eject the drive - if the drive does not work here > your drive needs a replacement. For the broken plastic panel, you can stick it with a quick stick glue if the drive ejects.
Posted on Jan 12, 2009
What is the correct way to open dvd drawer on Dell Inspiron 1525 laptop?
use the button on the draw or open or by clicking on dvd in folder view or PC window.
May 22, 2016 | Dell Computers & Internet
Dvd is jammed
If the DVD player/drive door or drawer will not open, try taking a regular metal paper clip, straightening it out, and inserting it into the small hole that releases the cover. Use a flashlight to look for this little hole, insert the paper clip straight in, and press firmly. The door/drawer should come open.
Oct 21, 2013 | Computers & Internet
Dell inspiron b130 Laptop
Try to remove the battery, turn the wifi switch off just connect it to the power socket and try to turn it on again, if this does not work, I think you need to take it to pc hospital
Jun 02, 2017 | Dell Inspiron B130 Pentium M 1.7ghz...
Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive cannot read to boot osDell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 22, 2012 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
CAN'T OPEN DRAWER
Hello
There is a motor along with belt to control the disc tray for every DVD player. If this belt or motor [loading motor] has trouble, the tray won't come out or get into. Check these for perfectness.
Dec 12, 2011 | Philips DVP642 DVD Player
MuWhen i turn the computer on the screen stays blank, the light on the far left hand side come on, but the screen stays blank - any solution? Thanks the computer is a Dell Inspiron 1525
clean the ram and check .. if same then u need to update the bios with programer.. u need to open laptop and remove the bios ... its all diffcult ... if any one has bios programmer ... i can send u bios updating file... u can contact me... thanks
Sep 13, 2010 | Dell Inspiron 1525 Notebook
My dell laptop inspiron 1525 wont play dvd's, but it will play cd's.. i have windows vista
Two things to check: First, look on the tray edge - does it say DVD and CD, or just CD? If it does not say DVD,it will not play them. The second thing is you may not have software to play a DVD. Usually Windows will use media player, assuming you have a dvd player. You can also open "my computer" and the drive will show up as a DVD or just CD.
Aug 12, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 wont play dvd movies anymore
for improve your media player and to read all Video and Audio Extension files you just download K.lite Codec pack in this below link
http://www.filehippo.com/download_klite_mega_codec//
This solution was prepared By Sami Jalal From Nehru Computer Center
May 16, 2010 | Dell Inspiron 1525 Laptop Jet Black
ILO dvd recorder
Try tapping lightly on top of unit after hitting the eject button
Jun 26, 2008 | iLO DVDR05 DVD Recorder
Dell Inspiron 1525 Notebook Logo
1,164 people viewed this question
Alun Cox
