Question about Compaq Presario 2545US (DC970AABA) PC Notebook
My Compaq Presario 2545 won't boot
I replaced the ac adaptor on the motherboard. It literally fell to pieces when I removed the soldier. Before this, the unit booted correctly it would not charge the battery or run with the ac cord. Now it charges and turns on with the battery and/or the cord but will not boot. It runs for a brief few seconds then the fan turns of and then nothing. No image or anything come on the screen. I can hear the dvd drive trying to run. It has a 4.2 Ghz processor, 512 MB or ram, and is running windows xp. How can I tell whether it needs another motherboard or just a bios update? I am stuck and can't figure out what to do next. Is installing another motherboard possible?
  • stephdawg40 Jan 13, 2009
    Well, I have reseated the ram (took it out and put it back in) and it still would not boot. The dvd drive will not open, so I can't even put in the boot cd. Do you have any others suggestions. By the way thanks for the help.
    I know that purchasing a computer would be easier. I really don't have the money to purchase another one. Using an external hard drive is definitely an option. One last question. What would it take to repair the BIOS? You have been very helpful and I am hoping that I don't have to take this thing apart again. I was able to get it back together with alot of headache. If I had the cash I would throw it as far as I could. Thanks again for all your help.
  • Compaq Master
  • 32,281 Answers
Try reseating the RAM
Posted on Jan 10, 2009
  • Chris Hingee
    Chris Hingee Jan 13, 2009
    Usually when a computer won't boot up is because it has faulty RAM or a faulty CPU or BIOS ot some other system component.
    Replacing motherboard is a lot of work, if it were me I would put my money towards a new laptop, it would be faster and more powerful.
    You can take out the hard disk and put it into a USB hard drive enclosure and use it as an external drive.
  • Chris Hingee
    Repairing the BIOS is very difficult, its a surface mounted device and you would need special equipment to remove it and to solder it. Even I would not attempt it.
    Getting a replacement new motherboard would be a better option, a second hand one would not be my choice (you could get a dud one, bit hard to test on its own).
    For a cheaper option, if you don't need a portable computer, get a desktop computer (a 2nd hand one would be OK, at least you can test before you buy). These computers are easier to upgrade and maintain because nearly all parts/components are cheaper, they also are interchangeable and available from a wide variety of sources.
My compaq f700 laptop won't boot up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the compaq f700 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 30, 2013 | Compaq Presario F700 Series Laptop...
Compaq Presario V3000 SUDDENLY DEAD
Remove the battery and try on the AC adaptor only. if it still doesn't work try a new adaptor.
Apr 06, 2012 | HP Compaq for Presario V3000 Motherboard
MY cOMPAQ pRESARIO CQ60 fell and cant complete boot
Most likely in this case, the damage is to the hard drive or its connection to the motherboard. The CQ series though has a three point screw attachment for the hard drive so Im more inclined to think that the shock of the landing has damaged the read/write head on the hard drive. If you happen to have another hard drive for a laptop, try installing a new drive and run the installation disc and see if it will complete and boot completely....if it will then the problem was the old drive.
May 23, 2010 | HP Compaq Presario CQ60-249US Notebook
What battery does it use s6200cl compaq presario
Most motherboards use a lithium CR2032, CR2025 or similar. This is about the size of a quarter and in a holder on the motherboard. Turn off the AC plug and then ground yourself so you do not zap the PC. You could do this on a kitchen counter and touch the faucet before the PC. Or use a grounding strap. Remove the battery and replace with new. The BIOS will have to get its wits about it again, so be prepared for a couple of boot cycles. Start conservative default settings before venturing to more adventurous settings. Note if you have a separate video card or not. If so, select the setting to use the card not motherboard on boot. This is the only show stopper for a setting. Once you have it up and going again, resist the temptation to close it up before one last boot cycle shere you write settings on a piece of paper and tape it to the inside panel of the PC. Good Luck!
Dec 28, 2009 | HP Compaq Presario S6200CL (B000649LKU) PC...
Compaq presario F700, on AC adaptor, power light comes on. then goes out, will not boot up
You may want to check your motherboard for bad caps.
You should be able to see the caps in and around the area of the CPU.
Some units have 10 or 12. The caps should be checked for crowning and possable leakage.
If this is not the case and the caps look to be good, you will want to check your power supply to assure that proper voltages are being delivered to motherboard.
I would remove CPU and memory, CMOS battery and reseat all removed. Install removed devices and check motherboard each time a device is installed. ( one at a time )
Good luck, I hope you have the good luck with the board.
Nov 27, 2009 | HP Compaq Presario F500 F700 and G6000...
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Can't get laptop to turn on. Battery pack lights show full charge, power cord is plugged in. No indicator lights illuminating at all, wondering if it is my motherboard. Compaq Presario 2200 laptop.
very first thing u have do is if u have any other laptop try and connect the aac adaptor with that laptop and also try the battery if it is working with the other laptop that means the motherboard of the computer has gone bad u need to replace it and what also u can try is disconnect the ac adaptor and take out the battery from the laptop and the without ac adaptor and the battery press and hold down the power button for one minute and then connect the ac adaptor and put the battery back in and then try and turn on the computer and also what u can do is shut down the computer first and then just hit the power butoon once only to turn it on and then keep tapping f8 key on the keyboard and it will take u to windows advance options and select safe mode with networking and then try if it turns on to the windows screen or not......and if it doesnt turn ono then definately replace the motherboard...good luck....
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario v2000 notebook will not boot up blank sreen
If it is working fine with AC Adaptor, change your battery it need replacement.
Feb 09, 2008 | Toshiba Satellite A15-S129 Notebook
Compaq Presario 2545US (DC970AABA) PC Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
