Question about Dell 924 All-in-One InkJet Printer
All-IN-One Printer 924 Deep Paper Jam, can not get it out
I was printing some stuff out, when I was about to make a test print, which I have done in the past, I put in a thinner type of paper which is the test paper. Again, I have done this before and it has worked fine. That paper got really jammed inside. I followed the troubleshooting instructions on Dell, but that is not helping. I stuck my fingers inside from the back of the scanning part, I felt a piece where I pressed down and I hear the paper, but I can not get to it.
The jam is very deep inside and I do not know how to get to it. I see screws all around the printer, I attempted to unscrew the ones in the back of the printer which are three, but that didin't help either. At this point I do not know what to do. It's super hard to get through to Dell, so this is my last resort right now.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
I had a paper jam. When I pulled the paper out
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 27, 2009 | Dell 924 All-in-One InkJet Printer
Will not print - for scann or print - makes the
Give this a try: Disconnect all the cables to the printer. Hold it upside down and shake it really hard for 30 seconds. This should clear anything stuck inside the printer.
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
Every time I try to print the printer just chews up the paper .
yes, there are still paper stuck in there.
turn off the printer and use dental tool and a flash light, slowly turn the paper pickup roller and check the either end of the roller, that is usually where the bits of paper are stuck.
make sure the pickup roller don't have any sticky stuff on them. that will cause the paper to jam up.
May 14, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam dell 924 inkjet printer
Is there a door or access on the back of the printer? Some printers can be accessed there.
Jan 12, 2009 | Dell 924 All-in-One InkJet Printer
My HP PSC 1402 won't print!
my system ever thing is ok,but once i put paper displaying a out of paper,how 2 resolve this problem
Jan 07, 2009 | HP PSC 1401 All-In-One Printer
Paper Jam
Open the tray and cover. Look out for any paper inside the cover.
Close the cover and tray firmly. Then check for a test page.
Let me know if I can assist you further. Don't forget to vote the solution.
Regards
Ellin
Sep 25, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Dell 924 Paper Jam
are you getting a jam error?
If not load a letter sized 8.5 x 11" inch sheet of paper or carstock in printer print somthing let paper get about halfway down in printer then uplug printer and plug it back up as it comes back on it will usally rotate rollers forcing the paper out if you used card stock this should be stiff enough to force the smaller paper out
Dec 07, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
