Question about Mitsubishi VS-50607 50" Rear Projection Television
I have a 1994 mitsubishi 50 inch projection no picture
Model number ts 5053 the picture just quit but i have sound?
  • 1 more comment
  • tiggor6 Feb 19, 2009
    Was hooked to surge protection cable box making noise puled power from wall plug plugged back in wall later now I have sound but no picture
  • joejjl Feb 21, 2009
    I have sound but no picture. At first I was able to hit the back of the TV and make the picture come back on, but now I can't. I suspect something is loose, but I've looked inside and can't find anything.
  • Anonymous Mar 22, 2009
    we have the same problem my tv is mitsubishi 50 inch model ts-5053 projection, no picture but have sound.
    Problem Solver:
  • 4 Answers
This answer from troylove solved my problem. troylove11
Rank:i have a 1994 mitsubishi 50 inch projection no pic - wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Mar 14, 2009
Mitsubishi TS-5053 rear projection TV-Sound but no picture
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Oct 19, 2009 | Televison & Video
Mitsubishi TS-50611 projection tv has no video
You can do quite a bit to narrow things down....
First thing, unplug the set and wait 10 minutes. Then plug it in and watch the green power LED. If it does nothing push the power button and watch the power LED. If the set doesn't respond hold down the MENU and INPUT buttons on the front of the set until the LED starts blinking. If it blinks at this time count the blinks and then repost.
May 26, 2009 | Mitsubishi TS-50611 50" Rear Projection...
TS 5053 Turned off and wont come back on
Try what I said for my solution. At most you will have to order the part online and wait for 3-5 days for delivery.
Apr 06, 2009 | Mitsubishi VS-5043 50" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
219 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
