Question about GE Spectra JGBP35 Gas Kitchen Range
GE JGBP34 (XL44) oven won't light
The top burners work, and the broiler works. The oven won't light. I suspected the oven igniter and replaced it. When observed with the oven bottom and flame spreader off, the new igniter does not glow at all. Any ideas?
  • 1 more comment
  • jjcurley1 Jan 10, 2009
    There is no pilot, there is a glow stick igniter. Also, I already tried replacing the igniter and the problem still exists. I tried the "relay contact operation test" on the bake contact, and get 0 VAC. I think I need a new relay or control panel? I'm having trouble locating the parts (or even a part number for the ERC-II Control Panel).
  • jjcurley1 Jan 19, 2009
    The bake relay was bad on the control panel. The oven works fine now.
  • TPBeach Mar 01, 2009
    my oven will not light (heat). the broiler will not work either. the surface units light just fine. i am trying to figure out what needs to be fixed or replaced but cannot figure it out. any help is welcome.
Look at Lower Igniter
Check these two Sites here:
I just got this same problem today. Will do the same thing as these guys said in the morning. Good Luck.
Love these fix-it sites.
Posted on Jan 10, 2009
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Feb 04, 2010 | GE Kitchen Ranges
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
Aug 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JGBP35 Gas Kitchen Range Logo
1,078 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
