Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Water has stopped coming out of the filtered water dispenser
Kenmore Elite Bottom Freezer Refrigerator
We have used this feature for the past several years. The water just stopped coming out. I removed the water filter and replaced it with the cap that came with the unit but this did not solve the problem. There are two nipples where the filter screws on to the refrigerator and water squirts out of them when they are pressed. It seems that the water is getting to the refrigerator like it should. The problem seems to be occuring from the point where the water is at the filter to where the dispenser is. Any ideas?
  • Anonymous Jan 15, 2009
    no water coming out of dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Posted on Jan 19, 2009
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have the Kenmore Elite Trio 795.75546401. There is a sheet of ice under the freezer draw. I cleaned it out and it came back. Have since shut off the ice maker and stopped using the water dispenser. I...
It is definitely the water filter. With the hardness of the water from our county I have to change our filter every 6 months. After replacing the filter be sure that it is seated well. It can leak if it is not fully engaged. Run water through the dispenser until the air is out.
Mar 02, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
We just replaced the water filter...now dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Jul 14, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio model#596.73503201
I believe you may be on the right track. Usually the coil for the water is behind the crispers. You can try taking the crispers out and use a hairdryer on air/no heat to speed up the coil thawing out.
Feb 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Interior Water dispenser not working
if you have not yet used it you will need to bleed the air out of the tank in the refrigerator hold the button in for a few mins to flush this out
Jan 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
183 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
