Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Removing connectors when replacing STK392-110
Do you have to unplug connectors from white holders
or remove holders with the connectors inside from board
my first time......don't want to break anything
thanks
  • 43 Answers
Sorry for the delay. You should only have to unplug connectors from their holders. Most of them are labeled with the same as the label on the board by the connector. 95% of the time the connectors only plug into one connector and you can't mess it up. If you call a repair man, it should only rewuire labor rates. Let me know
Posted on Jan 12, 2009
How to install transferbelt
  1. Remove or slightly pull out Tray 2 (RM1-1916-000CN).
  2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
    assembly.
  3. Open the front door
  4. Remove the right cover (RM1-1858-000CN), carefully twisting the front edges of the side covers
    outward to remove.
    NOTE :
    To make the removal of the right cover assembly easier, release the tab on the inside of the cover.
  5. Remove the left cover.
  6. Squeeze the white link lever on the left side.
  7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
  8. Close the ETB.
  9. Remove the small black cable cover (RC1-5147-000CN) on the left side of the printer by carefully snapping it out of place.
  10. Remove one (1) grounding screw from the ETB harness.
  11. Pull out the white wire holder by pushing it up.
  12. Pull out the ETB connector.
  13. Remove one (1) screw from each hinge cam on both sides.
  14. Using needle-nose pliers, remove the hinge left cam (RC1-4249-000CN) and the right hinge cam (RC1-5311-000CN).
Remove the ETB. Use the following procedure to replace the ETB.
  1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left side.
  2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE :
When replacing the right cover, align the tabs on the upper edge of the right cover and lower edge of the face-down cover with their respective slots.
Nov 19, 2013 | HP Color LaserJet 2600n Printer
Install grohe shower bar
After removing from wall by unscrewing long screws after removing cap, look inside and you will see a white translucent plastic with 4 wide, flat hooked ends. Take a small screwdriver and gently push each 4 plastic hooked ends and it will come unhooked from the small groove. Push it far enough that the bar will slide out. No need to remove the plastic hooked piece. To replace, push in each hooked end and push in from the opposite end to reinstall.
Oct 14, 2012 | Grohe 24'' Relexa Shower Bar with Swivel...
Oven will not heat
the bake element has failed. they can be had for around 20 dollars. Unplug unit before
replacing the element. Usually will only need 1/4 inch nut driver to remove two
screws inside oven and slide out element and unplug the spade connectors.
The model and serial should be located behind the lower drawer on the left side.
An appliance parts store should carry this in stock since many models utilize the
same element. Hope this helps.
Sep 25, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Ghw9100lw keeps throwing code f/h help
Unplug power cord. First try to clean drain tube by removing bottom cover: uncrew two bolts on each side. clean tube and filter and pump. If it is fixed, you are done.
If problem comes back, unplug power cord as always. Remove top cover and replace water inlet valve (remember to shut off water valves both hot and cold), unplug connectors to blue switch and remove water flowmeter, blow air thru one end and then the other end to remove dirt inside white water flowmeter. If flowmeter bad, replace it.
Last thing may get bad is pressure switch which is brow color valve on the right side of machine.
Good luck
Jul 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I replace the parking lights on the front of a 2002 Toyota Tacoma?
1. Open the hood.
2. Remove the one screw holding the side marker housing inside the engine compartment about half inch from fender edge.
3. Pull the side marker and unplug electrical connector.
4. Remove bulb holder counterclockwise.
5. Pull bulb straight out.
6. Reinstall in reverse order.
Mar 21, 2010 | 2002 Toyota Tacoma
How do i change a brake light bulb on 2000 vw jetta?
Removing:
  • Switch off all electrical consumers, switch off ignition key and remove ignition key.
  • Remove rear luggage compartment side panel trim (left or right).
  • Remove 3 nuts, arrows, and remove housing.
  • Remove bulb holder.
Installing:
  • Install bulb holder.
  • Insert housing into body opening.
  • Tighten nuts.
  • Install applicable rear luggage compartment side panel trim.
Rear Light Bulb Holder Removing And Installing:
Removing:
  • Disconnect electrical connector.
  • Depress retainers, arrows, and remove bulb holder.
98971817.gif Installing:
  • Install in reverse order of removal.
And the Center Mounted Brake Lamp.
High mount Brake Light Removing And Installing:
The high mount brake light is installed in the rear shelf.
98971288.gif Removing:
  • Disconnect electrical connector from high mount brake light.
  • Remove rear shelf
  • Un-clip high-mount brake light from rear shelf, arrows.
NOTE: The bulb holder base plate contains soldered- in light emitting diodes (LEDs) that are not replaceable. In the event of LED malfunction, replace complete bulb holder.
Additional
Mar 13, 2010 | 2000 Volkswagen Beetle
LE error messaage. Manual says motor overload. Is there a reset button?
It is a locked motor error. One of the following is causing the problem but you may need the help of a qualified appliance technician:
  • The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of the stator assembly. Connect them properly.
  • The electrical contacts between the connectors (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main board assembly is bad or unstable. Trace the motor harness back to the main board. Clean the connectors and connect them properly.
  • The motor harness between the stator assembly and main board assembly is cut or open. Reconnect or rewire.
  • Motor winding is defective. Check the resistance between the terminals of the stator. Resistance should be between 5 to 10 ohms, otherwise replace the stator. Refer to the illustration above for the stator removal.
  1. Disassemble the back cover.
  2. Remove the large bolt on the center shaft. Ask your helper to hold the inside of the drum.
  3. Pull out the rotor out of the shaft.
  4. Remove the 2 screws from the tub bracket.
  5. Remove the 6 bolts on the stator.
  6. Unplug the 2 connectors on the stator.
  7. Pull the stator out of the tub.
  • The hall sensor is out of order/defective. It is located at the stator assembly. If the hall sensor is out of order, it cannot detect magnetic field and the main board sees it as the rotor is locked then displaying the error code. Replace it if no evidence of defect is found above.
Nov 23, 2009 | LG WM2688HWM TROMM SteamWasher
How do i remove rear light cover to change stop light 1995 vw gol
OPEN REAR HATCH & TAKE TRIM OFF LEFT OR RIGHT SIDE & TWIST BULB HOLDER OUT OF BACK OF LIGHT
Feb 10, 2009 | 1995 Volkswagen Golf
Bosch Washing machine broken, flashes F04
We keep getting this but can get around it.
You probably have a blocked pump/filter. If there is still water in the machine you will need to drain this first. So...
First try this. If it's finished the washing phase turn off the machine (rotate the dial to off then turn off at mains), leave for a min and turn on again at mains, then move dial to the rinse cycle.
If this works then it may clear the blockage for you. If not go to the bits below.
1. Remove the covering from the bottom RHS of the machine
2. There is a small black hose. Pull out and place in suitable container/bucket then unplug the end.
3. Will take quite a while to remove all the water. (Tip - once water is well below the window level unlock door and remove washing).
4. Once all water removed replace hose top and unscrew anticlockwise the white holder to the right of the hose. Make sure you have a towel handy to mop up any excess water.
5. Remove and clean all junk from it under a tap.
6. Look and see inside hole if any debris wool/cotton etc is blocking impeller and remove if necessary.
7. Replace holder.
et voila it should work again!
If not you have probably have a blockage somewhere in the pipe inside the machine. Sorry can't help with that one.
Apr 30, 2008 | Bosch Washing Machines
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
