Question about Maytag PYE2300AY Electric Dryer
Maytag performa dryer takes a long time to dry clothes on auto
Now when I open the dryer door to check the clothes, there are water droplets on the door and in the dryer.. there also is a foul odor when I open the empty dryer to put the clothes in.. I pulled the dryer away from the wall and noticed a tiny bit of water under the dryer after drying a large load??
  • Anonymous Mar 26, 2014
    dryer senses clothes are dry when they are not. very steamy when you open the door and it says the clothes are dry. Run another cycle, still not dry.
    Scholar:
  • 58 Answers
What you have is a obstructed dryer vent. If you remove the vent hose from the unit you will see moisture inside it. This is why your unit isn't drying. If the heater has no air flow the overload is tripped. Check your vent for any blockage most of the problem is at the outside end of your vent. there's a flap or chicken wire you may find the obstruction there. Or you can use a leaf blower connect it to the inside vent, cover the outside vent with pantyhose. ( so you don't get lint allover your yard ) and you can clear your like that way. Good luck hope this helps
Posted on Jan 10, 2009
My Maytag Performa electric dryer heats and tumbles, but the clothes take multiple cycles to dry, and water is pooling next to the left front foot. We cleaned the vent, replaced the vent hose, and opened...
two things come to mind; 1. although drum is rotating perhaps it is slipping under load. Change drum belt, and, 2. perhaps the problem isn't in the dryer, it could be that your washer is not spinning out properly leaving an inordinate amount of water in your clothes which would tax the performance of the dryer. Just a thought. good luck!
Aug 19, 2013 | Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
My dryer is taking to long to dry clothes and the setting dial moves very slowly if at all.
Make sure the exhaust vent is free and clear. Lint build-up can cause it to take longer to dry clothes. Also, try putting the timer on another setting to see if it makes a difference. If you are using "Auto", try putting the setting on a manual time setting to see if that helps. You may have a bad timer or bad moisture sensors.
Feb 24, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
MAytag dryer will not run. Has Power but will not start. No sensing light.
Was your dryer taking a long time to dry clothes? If so you should first check your vent and then suspect your dryer thermal cutoff.
Or,
this problem could be your door latch switch. Is your door more difficult to open, OR, sometimes pops open / or opens really easy? Then your door latch switch could be bad.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Dryer not drying clothes
Check your heating element your lint trap and your exhaust hose.
You can check the element by opening the door pushing in on the switch and turn it on,you will feel or see the heat.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 18, 2009 | Maytag Performa PAV2200
Maytag PYE2300AY Electric Dryer Logo
340 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
