Question about Garden
I need to remove the engine from my 8hp troybilt horse how do i d
I am replacing the engine on my 8hp troy tiller, how do I get the old one off?? the engine mount bolts?? I am replacing my tec. with an IC Briggs 8hp
  • 1 more comment
  • trailerman_6 Jan 10, 2009
    how do I get to the bolts?? I realise the bolts but I cant get into them
  • diggin dirt Mar 11, 2009
    where did ya get ur motor i need to do the same thing on my troy
  • rjonese53 Mar 31, 2009
    I need to remove the engine from my troy bilt horse tiller.
  • 33 Answers
Should be 4 mounting bolts
Posted on Jan 10, 2009
I am in need on line of the owners manual for troybilt "8-hp Horse" tiller and fluid capacities and type/weight of oil used in front transmission and rear tine gears. Thank you, Sincerely, Wm....
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
http://www.manualsonline.com/
http://dl.owneriq.net/7/7ba1d4f6-61b9-4c56-b878-fcfa51ddfeef.pdf
Apr 12, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
I HAVE A 8HP HORSE TROYBILT TILLER. I CAN NOT GET ANY GAS INTO THE CARB. I HAVE CLEAN GAS, NEW HOSES, AND CLEANED THE CARB. THE FLOAT IS NOT STUCK, ANY HELP?
have you checked to make sure your fuel shut off valve is turned on? If you remove the fuel line at the tank( with something to catch the gas) and your fuel shut off is turned on and you get no flow then something is clogging the fitting at the tank or inside the tank. You will have to remove and clean the tank. Let me know how you come out.
Frank
Sep 27, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Need a manual th1003 serial number 83233 troybilt horse
Ebay has manuals that they say are for all troy bilt tillers on cd for $6.99 free shipping.
May 24, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How to attach hiller/furrower to troybilt horse tiller
how do you attach a furrower to a troy-bilt "horse" tiller
Apr 14, 2010 | Troy-Bilt Pony Garden Tiller
What is the easyist way to change belt on older troybilt horse tiller without pulling motor
You dont need to pull the motor ... in fact if you do , that will not help you. We are talking about a genuine Troy, right? Bujilt in Troy not Cleveland.
At most, you will have to remove th reverse disk.
Take off the off the old belt(s) (mine 6 hp Horse is a older two belt drive). You must be in neutral. Pull the belt off the back of the engine pulley and down to give you slace to get it off the transmission pulley then pull it away.
It is very easy to say and a llittle harder to do but not as hard as you think, believe me. I have 2 belts and have replaced them several times.
YOU CAN DO IT>
Oct 08, 2009 | Troy-Bilt Pony Garden Tiller
I have a horse model about 35 years old with a kohler motor 7 horse. What new motor fits. serial no. 360331
In my opinion, (which doesn't count for much, I know) the 7hp Kohler Troy Bilt Horse tiller was the best tiller ever made. Those tillers lasted forever if they were taken care of. I've got one of the 8hp Kohler versions, but it's just not the same.
It's become a lot harder to find an engine to replace these engines. You'll most certainly want to go to a Briggs and Stratton dealer and have them look it up. You need a 3/4" crank, 2 7/8" long with a keyway, tapped for a bolt to hold on the pulley and reverse disc. IF you find an engine to fit, you'll likely need to have a custom throttle cable made up to replace the current one. A good small engine dealer should be able to help you.
Now for the bad news. The 7hp Kohler was a cast iron engine. Any replacement engine you find will likely be an aluminum block with a cast iron sleeve and therefore, much lighter. What this means is the balance of the tiller, from front to back, is going to be thrown off. The result is - it will be MUCH harder to pick up the rear of the tiller when you want to turn at the end of the garden. You will most likely need to either put on one of the bumpers (if you can find one to fit) or figure out a way to hang some weight on the engine. I've seen people do some creative things to get the balance back. Whatever you do, it just won't be the same as that great 7hp Kohler. I'd suggest trying to rebuild it - if possible!
Jun 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have 8hp troybilt horse rototiller. when i pull the starter rope, it doesn't engage. so i took it apart and i see that the place, where there are some ball bearings that are supposed to engage and turn a...
the pully teeth that you are tallking about can easily be sprayed with WD-40 or equivellant. Than keep working it and it WILL eventually come loose. I have worked with small engines for 10 years. This should solve the problem
May 09, 2009 | Troy-Bilt Garden
How do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
May 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
453 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
