Question about Dryers
Wiring diagram? I have a ge motor Model # G553 5KH45CR365. 115v 1725 rpm. there are four different wires coming off a terminal block. #1 is White size 12 guage, #2 is Red size 12 guage, # 4 is blue 16 guage & #5 is white 16 guage. Question are the two larger wires the White and Red are they the power leads? and where are the other two wires go?
  • Dryers Master
  • 8,220 Answers
They ain't power leads. They carry heat element current from the cent sw when the motor is running.
Posted on Jan 10, 2009
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
Can't find a wiring diagram for a Delco 1/6 h.p. Mod A221-cc Elect motor
I am sorry but we have no wiring diagrams here at fixya.
Jul 27, 2012 | Cars & Trucks
Ge timer 15350 110 4 wires 4 post have 2 white on post 1 1 bk on post 2 0 wires on post 3 1 bk on post 4 2 grounds to the box pump will work manually timer will not work
Unknown if this is new installation, or existing install that stopped working.
Copy following link for wiring diagram showing GE 15350 timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Look at terminal labels, should be L 1 X and 2
Power coming from breaker should be 120Volt Black Hot wire, and White neutral wire.
Cable going to Load should be Black and White.
White wires should be on terminal X
Black Hot should connect to terminals L and 1
Black to Load should connect to terminal 2
If your timer looks different, repost question with link to photo on flickr
If timer stopped working:
GE15350 timer is 120 volt timer made by Tork.
It uses P47 trippers, and Tork 101 clock motor.
Jul 04, 2012 | Hardware & Accessories
Installed timer and I'm getting breaker pop. I've tried several different ways to wire and it keeps poping the breaker. GE Replacement Timer 15600
1) If you are replacing T103, the T103 can be wired many different ways. Not all wiring diagrams are supported by GE 15600 replacement timer that fits into Intermatic box.
2) Double check your T103 terminals
T103 terminals should be A 1 2 3 4
If terminals 3 and 4 have wires, then GE is not correct replacement.
You can buy repair parts for Intermatic timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
3) GE has terminals 1 and L which are connected by brass bridge. If brass bridge is removed, add a jumper wire and connect terminals 1 and L
GE has terminals 1-L X 2
4) Typical GE 15600 wiring shows on following link, in addition to links for parts and manual:
White wires on terminal A connect to terminal X
Black wire on terminal 1 connects to terminal 1
Black wire on terminal 2 connects to terminal 2
Sep 11, 2011 | GE Vacuums
How wiring intermatic timer t51211bc i have one circuit control by timer ....and one circuit contro by photocel indor lite and outdoor lite
T51211BC is 120Volt timer that can be wired many different ways because there are two internal relays, and each relay has NO and NC terminals. One relay is controlled by timer dial trippers, and other relay controlled by dawn-dusk photo eye
Timer wiring cannot be fully explained with words.
Below is basic hook-up for your 120Volt wiring application, and then you can use a tester and experiment with the knob settings, and tripper settings.
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour%207%20day/t50000%20series%207-day%20time%20switch.aspx
1) You have 4 cables:
one cable from circuit breaker box;
one cable going to photo control;
one cable going to outdoor Load (lite);
one cable going to indoor Load (lite).
2) Cable from circuit breaker has 2 wires:
Black Hot wire connects to terminal 1
White Neutral connects to terminal 2
This will power the clock motor and timer relays.
3) Photocell has 3 wires:
Black connects to terminal 1
White to terminal 2
Red to terminal 3.
Photocell turns relay on-off for Circuit B
Do not mix different size wires under same screw terminal, or smaller wire will come loose over time. Also do not mix stranded wire and solid copper under same screw terminal for same reason.
4) Terminals 4 thru 12 are 'dry'.
Dry terminals receive no power when power is applied to terminals 1 and 2.
To put power on dry terminals, so that Load will have power, attach Black hot wire from breaker to terminals 9 and 12.
So add a jumper wire from terminal 1 to terminal 9 and another jumper wire from terminal 9 to terminal 12.
120Volt power is now connected to terminals 1, 9 and 12
5) Circuit B is dawn to dusk for outdoor Load.
Outdoor load cable has Black and White wire.
Connect outdoor Black wire to either terminal 10 or 11.
To test which is correct for your application, set switch to Auto, and then test across terminals 12 and 11, and across terminal 12 and 10. Repeat test after dark. Rotate knob B to each position and repeat test.
Connect outdoor White wire to terminal 2, and this will complete the circuit.
6) Circuit A is Dusk ON and timer OFF
Indoor cable has Black and White wire.
Connect indoor Black wire to either terminal 7 or 8.
To test which is correct for application, set switch to Auto, and then test across terminals 9 and 8, and across terminal 9 and 7. Repeat test after dark. Rotate knob B and repeat test.
Aug 04, 2011 | Day-Timer Intermatic T51211BC 7-Day Dial...
I had an intermatic 220 timer that died. I am trying ti reconect my wires to a replacement timer from GE. The GE is the 208-277 VAC. On the intermatic there was two red wires connected to the second...
Necessary for you to match up terminal numbering with actual numbers for each timer.
Information below is for 240volt timer controlling one single 240Volt load.
GE15601 has terminals L 1 X 2 from left to right
Intermatic T104 Has terminals A 1 2 3 4 from left to right
Here's the crossover from 240Volt T104 Intermatic to 240Volt GE 15601 for single-240Volt-load
Intermatic terminal 1 connects to GE terminal L
Intermatic terminal 2 connects to GE terminal 2
Intermatic terminal 3 connects to GE terminal 1
Intermatic terminal 4 connects to GE terminal X
Intermatic terminal A is not used in typical 2-wire 240volt circuit.
More links:
http://waterheatertimer.org/GE-timers-and-manuals.html#15601
http://waterheatertimer.org/images/GE-15307-wiring-250.jpg
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
Jul 30, 2011 | RTO Intermatic T106M Timer Mechanism Only...
I have a new GE 15306 Mechanical Time Switch and need to wire it up to 2 white and 2 black wires that I had on my old timer. I need more information on the wiring than is on the diagram on cover of metal...
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
GE 15306 is a version of 120Volt Tork 1101 indoor-outdoor timer sold at Home Depot under GE name and number.
You have 2 cables.
One cable comes from Breaker box, and other cable goes to Load (light, fan, motor, pump).
Each cable has black and white wire.
1) Cable from breaker box: Black wire H Hot connects to to terminal L.
Notice there is a metal bridge that connects terminal L and terminal 1.
If metal bridge is missing, use a jumper wire and connect L and 1.
White N Neutral from breaker box connects to terminal X.
2) Cable going to Load:
Black connects to terminal 2
White connects to terminal X.
So both white wires are on terminal X.
Jul 14, 2011 | General Electric GE 56941 24-Hour Outdoor...
How to change Emglo air compressor from 220v to 110v. Compressor is running at half speed when plugged into standard wall outlet. I bought the compressor new in the early "90's" and since then...
Hi Pete,
On the side of the motor on the label should be a wiring diagram. The diagram will tell you how to wire fro high 220v and low 110v ...
If the nameplate is single voltage only then the motor cannot be rewired for the lower voltage...
Also check the motor RPM nameplate as compared to the others...you may have a 1725 motor and the newer ones a 3450 motor...that would give them double the RPM's if the gearing or pulley sizes are the same...so.. if you have the right voltage and the RPM's of the motor are the lower, then you possibly could change the pulley sizes to speed up the compressor...
Lots to check and think about...
heatman101
Mar 11, 2011 | Dewalt Air Tools & Compressors
I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
May 25, 2010 | Campbell Hausfeld Tools & Hardware -...
Dryers Logo
303 people viewed this question
Top Dryers Experts
