Question about Microsoft Windows Vista Ultimate Edition
I have a code 10 it says it cant start wan miniport(atw)
    President:
  • 1,179 Answers
You need to update the driver as code 10 is a driver issue. Hope this helps.
Posted on Jan 10, 2009
GETTING A MESSARE...WAN MINIPORT 2 AND 3 CANNOT START
Go to device manager and delete those and then power the unit off and on and see if they are redetected.
Apr 08, 2014 | Dell Studio 1555 Laptop Computer 15.6-Inch...
America Online, Inc. WAN Miniport driver code 52
You may need a newer driver. Or, it is not the correct version for your OS. Check with AOL for updated / correct driver.
Oct 12, 2012 | America Online, Inc. WAN Miniport
TATA PHOTON+ Dialer Error 720: A connection to the remote computer could not be established. You might need to change the network settings for this connection. Can anyone fix this problem??? I'm using...
f you are experiencing this when trying to use Dialup Networking (ThinkPad Modem) or Verizon VZAccess Broadband, the following may be useful. Note, the solution involves modifying the registry on XP so it is not for the faint of heart.
Note that a key symptom of this problem is that the modem connects and then disconnects just after trying to register the computer on the remote network.
Step 1: Uninstall the WAN Miniport (IP) and WAN Miniport (PPTP)
IMPORTANT: This procedure contains information about modifying the registry.
Before you modify the registry, make sure to back it up and make sure that
you understand how to restore the registry if a problem occurs. For
information about how to back up, restore, and edit the registry, click the following
article number to view the article in the Microsoft Knowledge Base: 256986
(http://support.microsoft.com/kb/256986/EN-US/) Description of the Microsoft Windows Registry
SYMPTOMS
When you try to use a dial-up connection to connect to your Internet Service
Provider (ISP), you may receive the following error message during the
"Registering your computer on the network" portion of the connection
agreement:
Error 720 - the connection attempt failed because your computer and the
remote computer could not agree on PPP control protocol.
Additionally, when you view the devices in Device Manager, you may notice a
yellow exclamation mark (!) over the icon for the WAN Miniport IP (#2) device.
CAUSE
This issue may occur if the TCP/IP protocol has become unbound from the
dial-up adapter, or if a conflict is created when a second WAN Miniport IP
device driver loads.
RESOLUTION
To resolve this issue, uninstall the WAN Miniport IP and PPTP devices.
To do so, follow these steps:
1. Right-click My Computer, and then click Properties.
2. Click the Hardware tab, and then click Device Manager.
3. On the View menu, click Show hidden devices.
4. Under Network adapters, you will see WAN Miniport IP
devices. If a WAN Miniport IP device is listed, continue to the
following step. If no WAN Miniport IP device is listed, go directly
to step 16.
5. Click Start, click Run, type regedit in the Open box, and then click OK.
WARNING: If you use Registry Editor incorrectly, you may cause serious
problems that may require you to reinstall your operating system. Microsoft
cannot guarantee that you can solve problems that result from using Registry
Editor incorrectly. Use Registry Editor at your own risk.
6. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-
08002BE10318}
7. On the Registry menu, click Export Registry File, type backup-key in
the File name box, and then click Save.
Note You can restore the changes that you make to this registry key. To do
so, double-click the backup-key.reg file that you saved.
8. Click each of the registry subkeys under this key, and then view the Data
column of the DriverDesc value to determine which of the subkeys
corresponds to WAN Miniport (IP). For example, the 0005 subkey.
9. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) or
WAN Minport (PPTP); (for example, right-click 0005), and then click
Delete. Click Yes to confirm that you want to delete the key.
10. Quit Registry Editor.
11. Right-click My Computer, and then click Properties.
12. Click the Hardware tab, and then click Device Manager.
13. On the View menu, click Show hidden devices.
14. Under Network adapters, right-click WAN Miniport (IP) and then click
Uninstall. Click OK to confirm that you want to remove this device.
15. Repeat for the WAN Miniport (PPTP).
Step 2: Reinstall the WAN Miniports
1. Find netrasa.inf in c:\windows\inf
2. Make a copy of the file and name it netrasa.inf.save
3. Open the orignal copy of netrasa.inf and place a semicolon
in front of the line that starts "Excludefromselect=\" and
and continue with all follwing lines and then end with
"MS_NdisWanNbfIn,MS_NdisWanNbfOut" under the [ControlFlags]
section. (all lines between)
Step 3:
1. Start a Add new hardware session (from Control Panel) and choose
that the hardware is already installed. Choose to "Add New Hardware"
and then select "Network Adapters" followed by "Microsoft" and then
both the PPTP and the IP Wan miniport one at a time.
(NO need to reboot between these steps)
2. After you finish both then reboot.
3. Select Start -> Run and type: netsh int ip reset c:\resetlog.txt
(For details, see http://support.microsoft.com/kb/299357)
4. Reboot and try your connection.
5. Delete the modified netrasa.inf and rename the original (which was saved as netrasa.inf.save) back to netrasa.inf
Jun 30, 2011 | Sony Computers & Internet
Dial up connection ends in error code 720, can't connect to the internet. Using a back-up pc that is terribly slow. would like to fix pc.
Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol.
To resolve this issue, uninstall the TCP/IP protocol, remove the second WAN Miniport IP device, and then reinstall the TCP/IP protocol. To do so, follow these steps:
  1. Uninstall the TCP/IP protocol. To do so:
    1. In Control Panel, double-click Network and Dial-up Connections, right-click Local Area Connection, and then click Properties.
    2. Under Components checked are used by this connection, click Internet Protocol (TCP/IP), and then click Uninstall.
    3. Follow the on-screen instructions to uninstall TCP/IP.
    4. Restart the computer when prompted, but click No if you are prompted to allow Windows to enable a protocol.
  2. Right-click My Computer, and then click Properties.
  3. Click the Hardware tab, and then click Device Manager.
  4. On the View menu, click Show hidden devices.
  5. Under Network adapters, there should be no WAN Miniport IP devices. If a WAN Miniport IP device is listed, continue to the following step. If no WAN Miniport IP device is listed, go directly to step 16.
  6. Click Start, click Run, type regedit in the Open box, and then click OK.
  1. Locate the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002BE10318}
  2. On the Registry menu, click Export Registry File, type backup-key in the File name box, and then click Save.
    Note You can restore the changes that you make to this registry key. To do so, double-click the backup-key.reg file that you saved.
  3. Click each of the registry subkeys under this key, and then view the Data column of the DriverDesc value to determine which of the subkeys corresponds to WAN Miniport (IP). For example, the 0005 subkey.
  4. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) (for example, right-click 0005), and then click Delete. Click Yes to confirm that you want to delete the key.
  5. Quit Registry Editor.
  6. Right-click My Computer, and then click Properties.
  7. Click the Hardware tab, and then click Device Manager.
  8. On the View menu, click Show hidden devices.
  9. Under Network adapters, right-click WAN Miniport (IP) and then click Uninstall. Click OK to confirm that you want to remove this device.
  10. Reinstall the TCP/IP protocol. To do so:
    2. Click Install.
    3. In the Select Network Component Type dialog box, click Protocol, and then click Add.
    4. Under Network Protocol, click Internet Protocol (TCP/IP), and then click OK.
    5. When the protocol is installed, click Close.
  11. Reset the modem by turning the power off and then on, or for an internal modem, restart the computer.
  12. Test your Internet connectivity.
May 02, 2010 | Acer Aspire T650 PC Desktop
I have exclamation marks on wan miniport sspt and wan miniport (network monitor)#2,i am having problems with my desk top (vista)how do i solve these problems
An exclamation mark means the driver is not installed correctly or the hardware is not being started right. In device manager, try right clicking the device and clicking uninstall, then click scan computer in the upper toolbar of the window to reinstall the WAN Miniport
Dec 30, 2009 | Evesham Computers & Internet
My drivers on my dell inspiron 1705 are having
try re-installing the drivers of these....if that does not work
check this
device manager/network adaptor/ur netwrokd card/properties/resources
check if that has any 'Conflicting Devices"
check if the IRQ # is not frozen
under the General Tab check if the Device Status is working properly etc
Dec 17, 2009 | Dell Inspiron E1705 Notebook
G wireless router
You should disable the WAN miniport pppoe. SSID is the wireless network name or the signal's name coming from your wireless router.
After disabling the wan miniport, Right-click on Wireless Network Connection > View Available Wireless Network. If you see several networks listed, highlight your wireless network and click Connect. That should do it.
Sep 28, 2008 | Linksys Wireless-G WRT54G Router
Corrupted network drivers
what OS are you running,
Try removing it and reinstall
if it persists then try another card
update drivers and this should fix the problem
another thing also worth thinking about....
Maybe time to consider formatting the system and reloading it again with a fresh install.
Aug 02, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Network adapter
Okay, thanks for that. Usually, the easiest way to repair a Code 10 error is to simply uninstall the device, then allow Windows to install it again. If you have an installation or drivers disc, this is good to have on hand, but it's possible that Windows may be able to automatically install it without requiring one.
To uninstall the device, simply right click on it in the devices list, select Uninstall, then restart Windows. When the computer restarts, it should automatically detect the hardware and attempt to install it. If it cannot find the driver without requiring a disc, you'll need to supply the disc that contains the drivers for the WAN miniport so that it can install it for you.
May 11, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
111 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
