Question about Panasonic KX-T7625 Corded Phone
Unhooked phone jack from back of KX-T7625 Corded Model and when I
Plugged it back in it was dead. No lights, no dial tone, what do I do?
    Problem Solver:
  • 9 Answers
Should just fire back up again, are you sure you put lead in correct socket? sorry if it seems a silly thing to say , but it is a common problem. Try resetting the system if the connections are correct.
Posted on Jan 11, 2009
No display and dial tone on panasonic KX-T7730
Check cable from the phone jack both ends and see if its plugged in. Also, check power cord if plugged in to the power source.
Sep 03, 2014 | Panasonic KX-T7730 Corded Phone
How to call outside.. by using external 2 up to 16
Has it worked before or it's a newly installed system.
Could be programming issues.
Try dialing 0 first > dial tone then outbound call.
Its either 9 or 0 depending on configuration
Jun 18, 2014 | Panasonic KX-T7730 Corded Phone
There is no response from the phone when plugged in to the telephone jack. No lights, no dial tone, nothing. As if its dead. The jack is ok since other phones work when connected to it. Its a hand me down...
What other phones work? Check the base cord and make sure it has 4 pins. If the jack works for other phones, then take that same cord and plug it into the base of the 7730. Worst case is that you take it directly to the phone system and plug it in there to see if it works.
Carl
Jul 26, 2011 | Panasonic KX-T7730 Corded Phone
My office phone rings and all the lights on the phone works.all the other phones in the office works.but, i have no dial tone or cannot hear anything on my handset or the speakerphone
A 77xx series phone is a Proprietary Analong telephone. It requires 4 wires to operate, the inner pair (your standard tip and ring) carries the voice and the outer pair carries the data. Guess which pair has a problem :-)
If you start with a regular telephone and plug it into the jack, you'll get dial tone. Work your way back until the regular phone works. Once it does, the 77xx phone will work. Also, to double check, take the system phone and plug it directly into the jack at the system cabinet. It should work or you have a defective base cord or phone.
Carl
Apr 15, 2011 | Panasonic KX-T7730 Corded Phone
I have a panasonic KX-T7625 and I would like to set it to go to voice mail after 3 rings. How do I do this?
On the intercom you dial *7104 xxx #. The xxx being your system VM extension (usually 500). Then you dial *71318. Note, the 18 is a 2 digit number for 18 seconds. That will make the 4th ring be into the voice mail system and it should answer on the first ring. You can adjust the time from 00-99, except after you get to 30 or so, the transer recall timer should pull the call back in before your phone answers.
After you dial the 710x code, you should be able to press the FWD/DND button and have it cycle between on and off. There is also a 3rd state DND, but it also has to be initially dialed from your intercom.
Carl
Jan 21, 2011 | Panasonic KX-T7625 Corded Phone
The panasonic kx-t7633 has a flashing light but not dial tone
What color is the flashing light? Green is an intercom call and red is a call from an outside line. First try a new phone line cord and check if you have a bad cord. Do you have dial tone at other phones/jacks in the building? Unplug the extension line and plug in a known working phone. The phone needs repair if the your alternate phone works. If the second phone doesn't work at the jack, then the problem is in the wiring (at the jack or in the rest of the wire run) or in the Phone system. Depending on the jack, you can open it up and determine if there are any loose/broken wires. A cable tester that can do telephone lines (RJ-11) will help (some of these will handle power on the cable so check the specs for your phone system). If the jack uses a keystone, you will need to open it up and press the wires back down with the appropriate punch-down tool. You may want to pull the wires up and press them down at a different point (closer to the outlet box).
If none of the phones work then it is the phone system or the wiring coming into the building. I do not know if you can get to the service box and plug in a phone there. If there is no dial tone at the service box, get the phone company to fix it. If the problem is the phone system, you will have to consult a service person who knows more about the system.
I hope you find the problem to be simple, like a bad cable.
Aug 17, 2010 | Panasonic KX-T7633 Corded Phone
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Bell phone
is your computer hooked up dsl or dial up? unplug all the phones and computer from the phone jacks.plug a corded phone into the jack and check for dial. if you don't have dial tone, call your phone company. if you do have dial tone, plug everything in one at a time and see if the phone line goes dead.if it does, the last thing you plugged in is the problem.
wg
Feb 10, 2008 | Lands Phones
Panasonic KX-T7625 Corded Phone Logo
88 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
