Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Blinks 9 times in a row
How do I fix it?
  • 1 more comment
  • JillyBohnson Nov 26, 2007
    It would take me a couple of minutes clicking the power button to turn the TV on and it would finally power up. Then it took longer and then it wouldn't power up at all. I get the 9 blinks. I herd changing one of the fuses would work?
  • patbu2 Dec 11, 2007
    I checked diodes and had a tech check them. They are ok. Re-soldered them, but still having same problem anything else i can check? Thanks Pat
  • Anonymous Sep 08, 2008
    my tv when u first hit the power button the standby light blinks 10 times then 9 and 9 there after how do i fix this problem
  • 934 Answers
If you're any good inside a TV option(1)is you need to replace D6116 and D6301 on G. board. They are located off pins 7&9 Of T6301. D6116 is a surface mount and in the past I've used a 1N4007 for both... Option (2) replace the G board new, but that's a little extreme. And the orignal Sony p/n# for that board #A-1054-157-A which is no longer available... So it would probably be $300+ dollars IF you could find it... Option (3) remove the G board and send it in to PTS Electronics for a rebuild. It will probably cost about $200 including shipping. And Option (4) find a reputable shop locally to do the repairs for you... I sincerely hope you'll find some of this helpful. If I can help in any way just let me know... premtech@willapabay.org 360-642-4993 Bill
Posted on Jun 06, 2007
Call 1800-488-7669 it will cost 65.00 to fix
Posted on Jul 26, 2009
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Normal light flashes, unable to operate
Hello.
The reason the ligh keeps blinking is because it is displaying a error code. How many times in a row does the light flash before it pauses and blinks again?? the number of times it blinks in a row is the number of the error code its displaying...example if it blinks 7 times in a row before a brief pause its is displaying the E7 code and so on.
This tip i wrote will tell ya how to reset the control board but be sure to reply with the amount of times it blinks and i will let ya know whats its telling ya.
Here is that tip to reset it http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 24, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Stanby light blinks 9 times after powering on but no picture
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections.
Hope that helps.
Jan 17, 2011 | Sony KDL-46XBR2 Television
TV won't turn on, standby light just blinks 9 times
hello, Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
regards
shaun
Oct 19, 2010 | Sony KP-46WT520 46" Rear Projection...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony kdf 55xs955
Low B error protect is what 6 blinks means on the LA-3 chassis
Jun 15, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
503 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
