Question about Miele S251i Plus Bagged Canister Vacuum
Opening Miele S28i Vacuum cleaner
I need to open the motor compartment of my Miele S248I vacuum cleaner. It had a bag slip out of place and a lot of dirt got into the motor compartment. I found and removed the two screws inside the lid, but something else is holding the motor cover in place. What am I not finding to take this apart?
  • 52 Answers
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Posted on Aug 19, 2010
My Miele upright vacuum will not start. The red light will come on but not the motor. Why is that?
I believe you should have an amber light, if you are seeing a red light located above the bag compartment door, that indicates a fault with either the electronic module or the motor. Unless you have a voltage meter and are familiar with pulling plastic tabbed appliances apart, I suggest you email http://www.mieleusa.com/emailtomiele/emailus.asp?nav=&snav=&tnav=&oT=66 or call direct. Residential Appliances or Vacuum Cleaners(800) 843-7231Monday-Friday:8:30 am - 5:00 pm ESTSaturday-Sunday:Closed
Mar 04, 2013 | Miele S7210 Bagged Upright Vacuum
Tip
How To Maintain a Miele Canister Vacuum
Here's a short Video Presentation that we've put together showing how to replace the vacuum bag, motor filter, and HEPA filter on the Miele Series canister vacuum, as well as how to perform basic maintenance.
How To Maintain a Miele Canister Vacuum Cleaner
on Mar 22, 2010 | Miele Aquarius S5580 Bagged Canister...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
How do I open my shark plus 1200w vacuum
place the vacuum cleaner in the vacuuming position with the wheels in normal rolling position. Slip your 4 fingers excluding your thumb into the hole located next to the nozzle(where this hose connects to the main body). Yank straight up and the bag compartment will open.
Mar 30, 2011 | Euro-Pro Vacuums
Replacement Motor for a Miele S143 Vacuum Cleaner
Your vacuum should still be under warranty. If they dealer does not fix it for free call Miele directly.
Jun 05, 2010 | Miele S143 Bagged Upright Vacuum
S248i canister vacuum: electric cord retractor kaput
It is pretty tough to fix a retractor. Maybe hook direct and wind up the cord manual like uprights.
Sep 14, 2009 | Miele Vacuums
Dust compartment lid won't close
Hi Depending on the filter you have, you need to check that the filter grid has been securely locked in at the back. Check that it "snaps" down and locks into place. Then check the position of the bag. If the bag is sitting on the rising bag lock slider then the hinged slider needs to be pushed down into the bin. Usually the lid will close and lock down if you remove the hose. Try this to see if it works. Then check to see that the bag is opened out where the hose usually goes - if the mouth of the bag (and this also includes the new HyClean range with the seals already built in) looks out of angle then it has slipped upwards. This usually happens if the bag hasn't been folded out properly and can take milliseconds to put right.
Then put the hose back in and lock into place.
Has this solution been Fixya? Please rate accordingly or msg again if you need more help.
Mar 28, 2009 | Miele S4580 Luna Bagged Canister Vacuum
Miele S251i Plus Bagged Canister Vacuum Logo
712 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
