Question about Vtech Lands Phones
GET A DIALING ON THE PHONE
I READ THE MANUAL AND HIT *TONE BUT IT DOES NOT GO BACK FROM THE DIALING.
IF I HIT *TONE BEFORE I DIAL IT WORKS -BUT WHEN I HANG UP AND TRY AGAIN-I GET THE PULSE DIALING.
HOW DO I GET BACK TO DIGITAL?
HANDSET OF VT2931 OF DIGITAL 900 MHZ
  • 4 more comments
  • geneb33 Jan 19, 2009
    I DID WHAT YOU WROTE AND IT DOES NOT SOLVE THE PROBLEM.
    I EVEN DISCONNECTED THE BASE FROM THE TELEPHONE AND POWER.
    BY THE WAY-THERE ARE NO 2 WIRES JUST THE BATTERY.
    PLEASE GIVE ME A SOLUTION!!
    I TRIED ANOTHER PHONE ON THE SAME LINE AND HAVE NO PULSE. THE BASE UNIT ON THE HANDSET ALSO HAS A PULSE. THE OTHER BASE UNITS HAVE NO PULSE.
    I HAVE THREE BASE UNITS AND 3 HANDSETS AND THIS IS THE ONLY ONE THAT HAS THIS PROBLEM.
    PLEASE HELP!!
    ON THE BASE UNIT THE MODEL NO READS
    VT2931
    DOES NOT WORK
    HERE IS A CLUE.
    WHEN I PRESS *TONE BEFORE DIALING-THERE IS NO PULSE
    THANK YOU.
    THERE IS A SWITCH
    THANK YOU.
    THERE IS A SWITCH
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It may just be a stuck button. Try prying it away from making contact underneath by flicking on it with your fingernail. Alternately, open the casing locate the button for the Tone/Pulse and with a cotton bud dippe in alcohol, clean the carbon contacts underneath.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 19, 2009
  • 11,896 Answers
Try press and holding the tone button.
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Jan 19, 2009
    Press menu and use the arrow down to goto Global setup and press
    select. Use the down arrow and goto Dial Mode and press select. Use the
    down arrow to select your dial mode and press select
  • Nate Stansfield
    I have looked at your phone's user manual. You are doing everything you should be. the fault is an electroncial problem in the phone
  • Nate Stansfield
    The setting on the phone and the base both have to be set to tone in order to work
    Brigadier General:
  • 5,158 Answers
Is there not a switch on the side of the base for tone or pulse dialing....
    Sergeant:
  • 378 Answers
Its a internal circuit problem in the device.or any of the buttons is getting stuck just make it clear.
    Sergeant:
  • 367 Answers
What is the exact model of the phone?
  • 2 more comments
  • Rob Houg
    Rob Houg Jan 19, 2009
    I am enclosing the manual for your phone and a picture of location of pulse/tone switch.
    Let me know if this helps
    manual
  • Rob Houg
    Please let me know if it helps
  • Rob Houg
    If the model you gave in your post is correct the manual and picture I posted should be the exact same thing as your phone. let me know if this is not the case.
    Rob
  • Rob Houg
    Sorry for taking the time to get you detailed picture etc of the phone and user manual. Thanks
  • 47 Answers
The problem may lie in you handets battery or.. the memory in the unit itself.. try using another phone on the same line.. if it uses pulse dialing then your line is pulse and is the problem..or it could just be the phone itself..
Posted on Jan 10, 2009
  • 505 Answers
If you unplug the battery for 2 minutes it will reset the phone. This may be a way to reset back if the phone is not resetting as it should. Remove the battery cover and carefully pull the 2 wire connector and wait. Hope it works
How do I get a dial tone.can answer the phone.just cannot dial out
I am NOT familiar with YOUR make and model of phone, BUT.... I've had several cordless phone systems over many years, and have had the same problem that you describe. First, here is some background info for you:
The telephone company systems USUALLY have two different dialing systems:
  1. The "old" ROTARY DIALS worked by MECHANICALLY sending out different numbers of electrical pulses which the MECHANICAL "receivers" at the phone company "Central Office" buildings would read and thus connect you to the dialed number.
  2. Some years ago, a "new" dialing system was initiated. That system was called Dual-Tone-Multi-Frequency [or for short, DTMF].
DTMF uses BUTTON KEYS which put out a different electronically generated TONE [related to] for each different NUMBER key pushed, and THAT series of tones told/tells the phone company Central Office receiver computer the number to which you wanted to be connected.
Around the world over the years, most phone companies have, and still use one of these two dialing systems, AND...
Most cordless phone manufacturers designed their phones to work WITH EITHER system, BUT....
The customer IS REQUIRED to "SELECT" which system his phone company uses, while the customer is "SETTING UP" his/her new cordless phone.
THAT process IS INCLUDED in ALL cordless phone set-up instruction packages I've ever seen!!!!!!
Either you need to carefully read and study YOUR installation-set-up instructions and then PROPERLY set your phone's dialing system [to PULSE or DTMF], OR GET SOMEONE who KNOWS WHAT he, or she is doing to do it for you.
I, and I think no one else is able to guide you via back and forth messaging on this site. At least I know I can't because I'm not acquainted with your cordless phone, AND I don't have an instruction/set-up manual to consult!!!!!
Track down your manual, OR search for a replacement manual; the dialer system selection process is NOT DIFFICULT IF you have the manual!!!!!!!
Nov 25, 2014 | Vtech CS6649 - Multi Handset Phone System
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
Can't dial out
bad phone or extension port try another working phone of the same type.
Aug 29, 2012 | NorStar M7324 Telephone
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
Phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Sep 04, 2009 | Uniden Cordless Telephone
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Oct 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
PHONE JUST A DIAL TONE?
Make sure your phone is in Tone and not Pulse dialing. To change it for your phone, just look in your manual. If you don't have one, I have included a link for you to d/l it.
Manual
Jul 18, 2007 | AT&T 1480 Phone
Can't dial out
What are you getting when you try to dial out? Sounds or display wise? How are you dialing out? Do you access a line, dial 9 from intercom? The dial tone is probaly the phone system generated dial tone. With more information, I can help..
Oct 25, 2006 | Nortel Meridian 9417CW 2 Line phone
Lands Phones Logo
29 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
