Question about IBM ThinkPad T30 2366 Notebook
T 30 IBM MEMORY PROBLEM
I see other people have the problem of one memory slot not working. Is this a problem with this model?? I tried to add 512 of ram to my laptop and bios still read 512. I pulled the new ram and put into the other slot and the computer reads this memory. Can it be that the two together aren't compatable together or is the slot just bad? Is there any fix to get more memory. Can i add 1024 ddr pc2100 to the good side??
  • 52 Answers
Hi!
Call 800-IBM-SERV and describe the problem. Say that you heard that there's an "engineering change" available to correct it, described in document MIGR-44772.
Repair should be free within the warranty period, and probably free even outside the warranty.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Posted on Jan 10, 2009
YES 1GB WORKS FINE
I have a T30 that has used one stick of PNY 1GB ram for a couple years now. I just started having problems and noticed that it doesn't like that stick any more unless I push on it (not practical at all) but it does like others. But that is how I also noticed the other slot doesn't work at all.
The one slot that doesn't work gives some beep codes that I assume are telling me there is no ram. The slot that does work won't do anything with the ram it doesn't like (unless I hold it down with my finger. Other ram it POSTs fine. So now I am looking into this MIGR-44772
Cheers
Posted on Sep 09, 2009
  • IBM Master
  • 32,281 Answers
IBM laptops are fussy with memory modules especially if they are from different manufacturers.A single 1Gb memory module should be fine.
Suggest you take your laptop to the memory supplier/computer shop and get them to fit the RAM so you can see your laptop working. That way they cannot say the RAM you return was
damage by you.
    Sergeant:
    Champion:
  • 258 Answers
It's either in the hardware or in the bios
Hi there. I am a RAM rookie. I have GAteway MX7118. are there two memory slots or one. It comes with 512 does that mean there are two slots and I can add a 1GB for A total of 1.5GB ?
Hi, defending on your cpu board usualy there are two slots, also if your board capable to 1 gigabytes memory, if your memory is DDR u can add 1 GB up . if your memory is SD you cannot add higher than 712 MB. if your memory is 512 and you want to add 1GB the total should be 1.5 you are correct in your calculation. thanks
Apr 29, 2011 | Gateway MX7118 Notebook
I bought a 2 GB memory for my Acer aspire from Crucial .com and replaced it with my 2x 512 MB RAM. It is working fine but I just want to know if I could add one of my previous 512 back to make it a total...
if you have an open slot it may work sometimes memory will not work with other memory of different bus speed. if the memory itself was meant to work in pairs it may not work as well. try it no harm can come of it. goodluck
Mar 19, 2011 | Acer Aspire One PC Notebook
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
I went and bought new ram for my computer. it's an IBM desktop. type 6792. a pc133 512MB sdram. my computer will not pick it up. how do i get the computer to pick up the ram? it is the right kind of ram?
I checked at http://www.buffalotech.com/products/memory/select/select-dimm/ and according the the memory configurator there your IBM Netvista 6792 takes this type of memory which can be ordered from them PC-133mhz SDRAM DIMM 168 pin, it indicated that your pc has 3 slots for memory and the maximum size you can put in each slot is 512 MB which would give you the maximum memory of 1536 MB. I have had problems in the past when replacing memory in IBM PC's some modules won't work because IBM uses different memory than other Manufacturers. But give Buffalo a try, their memory is guaranteed.
Apr 05, 2009 | IBM NetVista PC Desktop
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
IBM ThinkPad T30 2366 Notebook Logo
655 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
