Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
Dryer wont heat up...initially i think the problem was that it wasnt stopping during the cool down phase, meaning, unless i physically opened the door or shut it off, it would keep running. Now it is not heating up at all!
  • Bugsy04 Apr 14, 2009
    The Tumbler works but it does not heat up
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
WHIRLPOOL LE7800XSN1 SUPERCAPACITY IMPERIAL 6 CYCLE INFINITE TEMP ELECTRIC DRYER NOT TUMBLING. HAVE HEAT. BELT ISSUE? BELT PART #? GETTING CONFLICTING ANSWERS FOR PARTS.
Go to www.repairclinic.com and enter LE7800XSN1. With luck, you will be presented with a list of common replacement parts (including the belt) and may be able to get troubleshooting information.
Sep 30, 2017 | Whirlpool Dryers
Dryer turns off before cycle finishes
if unit has auto temp control,you may have a bad thermistor,,,,,make sure door is latching tightly,could be pushed open during cycle stopping it
Mar 03, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Looking for the age of Whirlpool electric dryer model number LET7848AQO Imperial Series CleanTouch 7 cycle 4 temp.
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
Sep 09, 2009 | Whirlpool Dryers
Turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Aug 09, 2009 | Dryers
My Whirlpool Imperial Series WGD5550SQ0 has low heat, does not start the way it used to. My wife has to alter the settings to make it work. What could be the problem?
The 'operating thermostat' is not working correctly. It should allow heating up to about 155 degrees F and then open for a short period and then re-close. This is the cycle during drying.
Jul 09, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Drier was working O.k . Timmer Stop working And so did the Heating. Does the Timmer control Temperature aswell.?
Yes, if the timer mech is damaged and, it will not rotate, this is cause the heating cycle to become inoperable. the time is responsible for initiating the heating command and the thermostat helps with the temp regulations. replacing the timer will restore the normal functions of your dryer.
Jun 18, 2009 | Whirlpool LER5636P Electric Dryer
It wont stop running... dries perfectly but wont stop. Thanks! ;o)
either a timer or the heating element or a blocked vent also there is a resister on some kenmore/whirlpool dryers and if it is out it wont advance in the auto cycles. It should advance in the timed cycle with or without heat
May 11, 2009 | Dryers
Whirlpool Electric Dryer wont turn on
Try this;
In your browser bar type in youtube.com
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Whirlpool GEW9250 Electric Dryer
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
1,113 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
