Sometimes the paperfeed light comes on, goes out, the printer beeps and then stops printing. When the paperfeed light comes on I take the paper out and start the process over. Does not work.Sometimes the paperfeed light comes on, goes out, the printer beeps and then stops printing. When the paperfeed light comes on I take the paper out and start the process over. Does not work.
You can't post conmments that contain an email address.
It's very easy to replace the drum unit. When you find Photoconductor unit there is a simple instruction on the box. You have to search for photoconductor unit type 1515 (also look for nashuatec, rex rotary, infotec or ricoh brands to see where you can find it on best price - 100EUR). If your mashine is printing fine, there is no need to replace the drum. You can only reset PM counter display if mashine stops. all the best pifonski
pf stands for print/fax. As far as i know it should not be able to scan but you can try the twain driver using a network cable.But don't think it will work.
this problem was not resolved as my problem did not relate to a gestetner machine but a Lexmark printer. At no time did I declare what machine I was using, and can only assume that the mix up occured when I was re connected after my first connection had ended prematurely.
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
