Question about GE WSXH208A Front Load Washer
GE washer WSSH300
Water do not enter
Shut water off at faucet's pull out washer disconnect hoses from back of washer at water valve look in valve to see if it is clogged with sand , lime or anything if so clean out. put hose end from washer in bucket turn on faucet to see if you have water there then do same with other hose. if all ok remove water valve check coils with volt/ohm meter if bad replace valve if good check at wires that plug onto coils on water valvefor 110 volts with volt ohm meter if uncomfortable with doing any of this Call Repairman ..
Posted on Jul 08, 2009
4 Suggested Answers
  • 12 Answers
SOURCE: my front loading GE washer WSSH300 will not drain.
Don't know if this will help or not, but your owners manual is available at http://genet.geappliances.com/DocSearch/Dispatcher
Water won’t drain
Drain hose is kinked or •
Straighten drain hose and make sure washer is not improperly connected sitting on it. Top of drain outlet should be less than 8 ft. (2.5 m)
above floor. Household drain may • Check household plumbing. You may need to call be clogged a plumber. Plumbing this washer directly to a pipe is hard on the motor. Usually the drain hose elbow is inserted in a stand pipe, meaning the washer would drain water on the floor is the stand pipe is clogged.
Several items can cause the lack of draining.
If you can get to the drain hose, try lowering to a point that it will drain into a bucket. If it drains the system is not clogged. If you advance the timer and the washer drains this maybe the culprit. The motor can overheat and shut off. I would advance the timer to spin and listen for a hum in the motor and then quiet, a sign that the motor has overheated. If the water drains it sounds like the timer is at fault.
I would first make sure the drain hose is properly installed and not kinked somewhere. In earlier GE's the water drain pump could clog, your manual doesn't indicate that as a defect. Regardless timer, motor and pump are in the cycle to empty the washer water.
Posted on Jul 11, 2010
taran_2005
  • 10515 Answers
SOURCE: ge wssh300 front load washer starts final spin
The spin problem could be a number of different things,one, the motor is bad, two your belt is bad, three the clutch is slipping, but as far as the suds goes how much detergent are you using and what kind? is the cold water coming in full force on rinse? if you have allot of suds this can make the machine not spin fast also.
The clutch is the most likely cause,these are not cheap, in fact it comes as the motor and clutch together on this.
If you are looking for a good reliable machine buy a top load direct drive whirlpool, no frills or bells and whistles and these run great for a long time and when they need repair these are inexpensive to fix. thats what i recomend.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 05, 2010
TheMobilian
  • 8220 Answers
SOURCE: GE WSSH300 Washing Machine clothes
Easy fix no service man needed. Hello! You got something in the pump filter.
Check out this bitchin pump clean out VIDEO
Feelin like fixing this puppy yerself? Service manual fer frontload GE
Posted on Jun 28, 2011
My front loading GE washer WSSH300 will not drain.
Water won’t drain
Jul 10, 2010 | GE WSXH208A Front Load Washer
Ge wssh300 will not start may, just beeps
hold the start and select button in for about 30 seconds together until you hear a beep; this resets the control panel
Aug 04, 2009 | General Electric WSSH300G Front Load...
GE WSSH300 stops after wash and need to hit start again to finish
Be sure to rule out one of the simplest things first---be sure the button that gets depressed when you close the lid is still functioning (or even THERE) Sometimes, if you have had a severly offset load, this switch can become damaged. Some washers will not continue to advance if it " thinks" the door is opened.
May 09, 2009 | General Electric WSSH300G Front Load...
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Sep 25, 2008 | GE WCVH6260F Front Load Washer
I have a new washer. Less than 2 months old. I always use the regular cycle but today I needed to wash a very small rug. I used the quick wash and iti took forever. Then at the end( after the cyle) the rug...
I just need help. I do not want to pay anything to have this question answered. I paid $1,200 for these two new appliances less than 45 days ago! I thought this site was connected with GE. Apparently not.
May 26, 2008 | GE Washing Machines
GE WSSH300G0WW front load washer
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
Sep 15, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
515 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
