Question about LG WM-2277HW Front Load Washer
I don;t have a problem with my LG front load washer purchased 4 yrs ago. But I need the matching pedatals (black) that I can't seem to find. any suggestions
  • 640 Answers
LG..com...go directly to there site,,,
Posted on Jan 10, 2009
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
LG no power unless I unplug it and reset it. Help please!
The control panel has a problem, check it or replace it
Nov 06, 2014 | LG WM Washing Machines
How to obtain fuel tank for a 212cc 6.5hp Pedator engine from harbor freight
im sure if you call them they can help, or take it to a bridgs and stration dealer and see if they have a match or can order one for you.
Sep 11, 2014 | Cars & Trucks
Samsung dryer makes loud noise; just started
'purchased approx. 2 yrs ago. always had trouble'?
Even whilst under guarantee/warantee?
I need to explain our situation.The washing machine forum is just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing mostly mechanical and electrical/electronic problems and giving guidance on these for free on the web. In addition the members are not 'affiliated' to, or representative of, any manufacturer of washing machines or detergents whatsoever so we have to be carefull what we say;-0)
Sorry but all I can suggest is that you call your local Samsung service agent to see if it can cure your problems. You do not want to go to the expense of purchasing a different washer!
If this has clarified the situation for you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 31, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
My LG front loading Washer 1.5 yrs old
They told you right. This problem has to be done by a service tech. If you are sure it is level and all feet are touching the floor when it vibrates it is an internal problem.
Jan 13, 2010 | LG WM-2077C Front Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
LG Front Load Washer
try leveling it, i had a nut that come off under the washer i had to put back on now it runs great
May 17, 2008 | Kenmore 43142 Front Load Washer
LG WD12311RD FRONT LOADING WASHER DRYER.
Those bolts have to be removed prior to use or you will damage the machine.  The drying issue has to be addressed by a qualified LG technician.
Mar 21, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
