Question about Singer Featherweight II 117
I have a Singer Featherweight 221-1 that won't form a stitch
I just bought the machine and the lady assured me that it worked o.k. but I can't get it to form a stitch. I am pretty sure that I have it threaded right and I changed the needle but it still won't stitch
  • Mazie Niles
    Mazie Niles Jan 10, 2009
    I have already checked that and it was in right but thanks for at least trying
  • Beth Gierman
    Beth Gierman Dec 12, 2017
    I was given a 221 featherweight. It will not pick up a bobbin thread.... hangs the needle thread on the bobbin assembly and breaks.
  • 27 Answers
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Posted on Jan 10, 2009
    Habit-Forming:
  • 84 Answers
I Love the Singer Featherweight! Likely, the top tension, or the bobbin tension is out of 'whack'. If you sew a few stitches on a double scrap of fabric, what do you see?
In a balanced stitch, the threads meet in the middle. If the top thread is straight, then the top tension is very tight. Loosen it. Ditto, the bottom thread. Loosening (or tightening) the bottom tension requires a very small straight/slot screwdriver. Most sewing machines come with a box of parts, and the screwdriver is one. Or find one.
When the machine skips stitches, the needle needs sharpening. If you take it out, and feel a burr - you can 'sharpen' it with an emery board. Both of my Grandmothers taught me that one. - Julia
Posted on Dec 15, 2017
  • Singer Master
  • 10,736 Answers
Don't for get to try a brand new needle. A lot of sewing machine problems are a result of old, dull, bent needles.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Usually, if the top thread will not pick up the bobbin thread, the machine is probably out of time--the needle and hook are not in sync. Search for sewing machine timing or take it for service.
Posted on Dec 13, 2017
I've had stitches go to pot w/ my Featherweight for the following two reasons: 1.  Needle isn't pushed far enough up into the shaft (most common     reason for me) 2.  Thread caught in bobbin assembly.  You have to unscrew the gib  screw and use a flashlight to find it.  Last time I did that, it was on a machine I'd just bought - 7 (!!) long threads were embedde there!  But it only takes one to mess you up. Good luck!  Vintage featherweights usually screw up because of the operator - I also learned THAT from experience!
Posted on Apr 23, 2009
You can only adjust tension when the pressure foot is down. The manual explains how to 'reset' the tension dial to read correctly. I'm a novice, but this is one of the first problems I had, the tension was so far off, the bottom stitch was pulling down the top stitch and ugh, what an ugly stitch.
Anyway, I'm still learning the tension and stitch lengths that work best w/what material. I hope this helps you.
Posted on Mar 27, 2009
Need instruction manual for singer, featherweight, 150 yr model
You can try to contact the manufacturer. They may be of some help.
Jun 05, 2017 | Sewing Machines
Bought a featherlite 221 will not pick up bobbin thread have no manaul so am i threading it correctly or putting in needle wrong the machine is like new
I see Singer Featherweight Featherlite manuals, not a Featherlite as a stand-alone model name. For the Featherweight 221 manual try here: http://www.singerco.com/accessories/manuals.html and enter the model 221. Alternative site: http://www.singer-featherweight.com/ with the direct link to the manual here: http://www.singer-featherweight.com/sitetwopages/singfea.pdf .
I hope this helps.
Apr 30, 2011 | Singer Sewing Machines
I have a singer featherweight, Serial number AL409402, I'm trying to find out if this is a model 221 by the serial number, can you tell me if it is?
Singer has on their web site with a database of their serial numbers. Since you have the serial number to your machine, it will be easy to find out.
Hope this helps.
Aug 10, 2010 | Singer Sewing Machines
It makes a rattling sound when I sew. It has been
If its an older singer featherweight it should sound pretty quiet but if its a newer 221 it has plastic or nylon gears and they can make a "barking" sound
Jul 16, 2009 | Singer Featherweight 132Q Mechanical...
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Singer Featherweight II 117 Logo
394 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
