Question about Kitchen Ranges
F.14 maytag gas range - Kitchen Ranges
  • 8,197 Answers
The error code F-14 indicates that the ribbon connector between the touch pad and the electronic oven control is disconnected. The recommended repair is to disconnect the ribbon connector from the electronic oven control and re connect it firmly.
If this doesn't correct the error code the recommendation is to replace the electronic oven control.
If you want to attempt this repair yourself, disconnect the power to the oven and open the door. Remove the three screws above the oven door that are holding the bottom of the control panel to the oven frame. Pull the bottom of the control panel out about 1 inch and down and it will release. The ribbon connector is a flat tape like cable, and there is a latch arm that you have to release before you can disconnect the ribbon.
Good Luck and please rate FixYa!
Posted on Jan 10, 2009
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Need parts to convert range from lp gas to natural gas
Contact the appliance manufacter and ask for a conversion kit. This should be done by qualified persons only.
Nov 28, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag gas range burner does not light gas valve does not work
It is likely that the ignitor needs to be replaced. If the range does not sense the correct amount of resistance in the ignitor, the range will not turn on the gas valve.
Sep 21, 2009 | Maytag MGR5750 Gas Kitchen Range
Maytag gas range does not light. Hot surface ignitor glows but oven never lights.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
thumbs up
Aug 17, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
No ignitors on gas range top
Pull out the bottom drawer and look for a cover over the spark ignition module. The ovens have glowbars and they have nothing to do with the top( different circuit).40a0b9a.jpg
Mar 11, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Maytag oven doesn't light, broiler comes on instead
On some gas ranges, the broiler comes on with the bake selection during warm up. This allows the oven to preheat much quicker. More than likely, the control pad is functioning properly and your bake igniter is bad. Igniters become weak with age and eventually go bad. Since the bake feature is used more frequently, it typically goes bad more often. The following link provides you with some guidance on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Remember: just because an igniter glows, does not mean it is good. If they become weak, they will not draw the required current potential to open the gas safety valve.
If you determine the igniter to be bad, you can obtain a replacement at searspartsdirect.com. Just type in your model number and go to the "Gas Controls" heading and look for item number 14 (part number 74007498). If the igniter plug does not match the plug you have on your oven, the instructions will guide you to cut the wires and splice the ends together. There should be ceramic wire lugs that come with the igniter kit. CAUTION: Make sure you only use the ceramic (heat resistant) lugs that come with the kit. Splicing with regular wire lugs or electrical tape will melt due to the heat. Additionally, make sure you UNPLUG the appliance before replacing the igniter. Live voltage potentials are still present with the range shut off.
I hope you find this information helpful. Let me know if you require additional assistance.
Nov 11, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Maytag MGS5870ADC
How does one adjust oven burner
Oct 21, 2008 | Maytag MGR5751AD Gas Kitchen Range
Maytag Gas range
We had the same thing happen and had the Atco Gas company come out to look at it.  Our regulator was not working properly which caused CO to be relased.  We were told that the problem could be fixed for about $250-300 (CAN.) including parts and labour.
Jun 09, 2007 | Maytag MGS5870 Gas Kitchen Range
Kitchen Ranges Logo
201 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
