Question about Whirlpool LGR6611L Gas Dryer
How to remove fan from dryer motor LGR6611LQ0
Replacing motor on LGR6611LQ0 and trying to figure out how to remove the fan from the shaft without breaking it. Motor # is #279827. Tried to turn shaft while holding the fan still. Motor will not fit through back panel. And no, having a 3rd tech come out to work on it isn't a choice. Thanks in advance.
  • 640 Answers
Ok corvett your there you just jumped one step..put the motor back and put the 2 motor clips back on,,,ok,,,,now you need to hold the belt side with a tool a grip pliers,,a wrectet head with handle turn which ever tool handle so it will hit the side of the cabnit the right side looking from front,,now wedge that tool..be careful go behind ,,put on worh gloves a must the side of blower wheel housing are sharp..caution got your gloves on,,now turn it to the left not the right,,counter clock wise..onthejob
Posted on Jan 10, 2009
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Dado
Nov 16, 2014 | Bosch Dryers
How to remove fan from back side of 80 series dryer so motor can be removed?
Hello John Bailey,
I believe if you look very closely... you will
see a splined (bronze) center bushing in the center
of the squirrel cage fan: Check for REVERSE threads.
A little penetrating oil and some FIRM pressure
should be sufficient to get the fan moving...
Force nothing ...
To get the ACTUAL cost of the FAN if you
BREAK it... you will need a COMPLETE model number...!!
Then go to... ( I don't recommend SEARS)
Search Over 2 1 Million Appliance Parts
Or shop on eBay for VERY competitive prices.
Hope this helps
Carnac the Magnificent
Dec 15, 2017 | Kenmore Dryers
Troubleshoot kenmore dryer
When I had the same problem I had to replace the dryer drive motor. The non replaceable thermo switch built into the motor is what kept stopping the dryer motor. On line videos were very helpful regarding changing the motor. I'd advise watching a few if you've never changed the motor before. The motor has a double ended shaft. One end drives the dryer. You probably saw that. Thing is inside the back of the dryer the other end drives the fan. Be very careful removing the back fan blade, it's plastic and not easy to remove without breaking it.LOOK FOR A VIDEO SHOWING THE FAN REMOVAL.
Feb 21, 2018 | Dryers
Can't remove dryer blower wheel
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Jan 27, 2009 | Whirlpool Dryers
Tring to get the fan off of the motor on whirlpool dryer
nothing,,you should have keep motor clipped down,,and first remove blower wheel its just screwed on the front side of motor,,put motor back hold the end of motor with wrench,,than turn blower wheel..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
LGR6611LQ0
you can but now you have to turn the motor shaft at the belt end..i believe you can put your adjustable behind the plastic square blower wheel shaft..on the motor shaft and try turning with your hand its hard to turn because the drum when turning turns the oppsite way,,im,,here onthejob..use gloves
Jan 10, 2009 | Whirlpool LGR6611L Gas Dryer
Motor replacement
there is a half in square drive recess in blower wheel insert half in drive into it ..usually a 7/16 open end wrench will hold motor shaft but if not use adjutable wrench to hold motor shaft at belt end turn blower clockwise ..if still can get loose use service tech method chisel and hammer ..if motor has overheated the heat will almost weld blower wheel to motor shaft ..by the way some parts houses may sell the switch as a separate part
Nov 24, 2008 | Kenmore 82822 Electric Dryer
Remove blower blade from motor
A guy who has been repairing these for twenty+ years told me sometimes the blower fan is just too tight to remove. If so, you have to use a screwdriver or punch from the motor side and literally break the plastic fan apart. I thought that was going to be my problem, but..... With wrench tightly fastened to the nut at the back of the motor and resting against the post of the rubber wheel, I put a sturdy wrench on the shaft at the front of the motor and whacked it in a clockwise direction with a hammer. It snapped and came loose! Hooray. Try that before you demolish the blower fan.
Jan 15, 2008 | Dryers
Can't remove motor from dryer
you need to pretty much disassemble the whole machine. the top cover comes off, the front panel with door comes off. the drum lifts out to access the motor as it is bolted to the floor.
Nov 29, 2007 | Whirlpool LEQ9858P Electric Dryer
How do you get the front cover off the dryer?
Try removing the back cover to gain access to the dryer motor and other bits. Feel around the drum and around the lip of the drum at the door opening. There could be a wire or chain stuck between the drum and the frame.
Nov 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool LGR6611L Gas Dryer Logo
124 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
