CANT GET ANY WEB PAGES 2 LOAD
Hi new problem...on my belco alpha 400 linux 2.4 i hav got the wireless connection working but istill hav a problem.i cant get any web pages 2 load, either wit the wireless connection r direct connection by the ethernet cable...canany1 please help.all it says is"unable 2 find proxy server" thanx forany help.and also is it possible 2 wipe the linux op off and install windows?
  • 585 Answers
Your laptop has an internal wireless and has the necessary software pre-installed. Is your wireless router or modem not found when you refresh the wireless networks list? If it is found, did you highlight it in the list and click on the "connect" button at the bottom of the screen? And does it indicate "connected"? You mention "Proxy server" is a proxy server required for your internet connection? If no proxy is needed for your connection, you should delete any such from the laptop's settings.
Linux and your laptop were rather made for each other. While I'm sure it's possible to buy a copy of the Windows operating system and install it on the system, you would need to boot from USB and use an external CD rom or somehow put the Windows installation disk on a thumbdrive and make the drive bootable. And then there may not be Windows drivers written for all of your hardware.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Jan 10, 2009
  • Bruce Volkers
    Bruce Volkers Jan 10, 2009
    I did a little Google searching and found reports that Windows will not install on your laptop. Therefore I would not even try to do so if I were you.
  • 238 Answers
If you still can't access webpages to load using different web browsers, then the problem is in your internet connection server. Also about your 2nd problem, go to this link:
How to remove linux and install windows xp
http://support.microsoft.com/kb/314458
Hi. I have a Vigor 2910g router. The router is working. Im trying to change the configuration, but i cant access the web page. Im connected directly to one lan port. I type the router IP in the web browser...
These are the general steps to all wireless connectivity.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Jan 31, 2011 | Draytek Vigor 2910G Dual WAN secure...
Problems connecting to my wireless network, and when it does it will not display the web pages
This model Sylvania has significant wireless issues under Linux. (which I'm guessing you have)
There isn't a fix to this unfortunately.
Sep 10, 2010 | Sylvania G-Netbook
Cant load a web page on my mac even though the router works.
go to network preferance and creat a new location and try.Also reset the smc and pram followed by Apple webpage.This will solve your issue. Also try checking different browser.
Mar 18, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Wireless status says i'm connected but cant load any web pages.
You need to go into it's set up and configure it right.
Using a Ethernet cable plug into the back of it with it on and type in http://192.168.0.1 start its setup wizard in your case.
Mar 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Can't browse my bank web site using Trendnet TEW-432BRP router.
When you are hardwired to the router you should disable the wireless internet access and enable the local area network.You should do the opposite when you are trying to connect to your router wireless.
Feb 28, 2009 | Trendware TEW-432BRP Wireless Router...
Cant get my belco alpha 400 linux 2.4 online by wifi
First of all does the modem say you Internet check the LED light or directly connect your laptop to it through the Ethernet interface looks like a phone plug but wider if you do have Internet the problem is with the router. it is not syncing with the modem this should be fixed by reseting or unplugging for about ten minutes if thats does not fix the problem you may have a faulty router or a modem doesn't send the right code to your ICP why you can get LAN Internet and not wireless is one of those mysteries.
Jan 01, 2009 | Computers & Internet
Internet problem
It could be several problems:
1. Your wireless router misconfiguration.
2. Your wireless router is bad
3. Your wireless card misconfiguration on your laptop
4. Your wireless card is bad.
If you never had problems with your wireless connection before and you haven't change configuration on your router or your laptop. I have seen and repaired this problem by replaceing wireless router.
Good luck!!!
Jul 04, 2008 | Computers & Internet
Difficult to Establish Connection
Do one thing at first you configure your dsl and after same configuration in the wireless g,
then configure the laptops to installed the card driver.and destops also where you want to installed
the card.
Jul 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Laptop wont load some web site pages
dl windows update and cutsum updates add in to it get all latest drivers for it vista ever mo u get new fixes ok also dl run cc cleaner free tool u can get online
Jan 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
