Question about Logitech EX100 967499-0403 Keyboard
Cap Lock Indicator missing
How can I tell if the cap lock in turned on as there doesn't seem to any sort of indicator on this keyboard
  • tidyone Jan 10, 2009
    I found a setting in the setpoint software, that comes with Keyboard and mouse, under tools that shows a status setting changes on screen (such as Caps Lock0 and every time I change the setting of the Cap Lock or Num lock it comes up on the screen saying whether it is turned on or off.
  • trq2 May 11, 2010
    I would like to turn the onscreen "caps lock" message OFF. Right now it appears each time I hit Caps Lock. Annoying. Any help?
    trq2@sbcglobal.net
    Scholar:
  • 91 Answers
You could turn on "Toggle Keys" (which is a feature in Windows XP) that plays a high-pitched tone when Num Lock is turned on and a low-pitched tone when it is turned off.
(Don't worry, the sound isn't annoying or anything)
To turn on Toggle Keys:
Open "Control Panel"
Open "Accessibility Options"
On the "Keyboard" Tab put a check mark in the box labeled "Use Toggle Keys"
Click "OK"
Give it a try & see if you like it.
Posted on Jan 10, 2009
  • 31 Answers
The best way is to open up a notepad document, and see if the letters you type in are in capital letters. You could also, however, download this free software that will indicate when your num lock, caps lock, and/or scroll lock are on. (this is, if you are running windows)
Posted on Jan 09, 2009
Cap lock indicator for asus n55s
the caps locks led is located on the led-bar above the keyboard.
May 06, 2014 | ASUS N53SV-XV1 Versatile Entertainment...
CAPS LIGHT WON'T COME ON
As you haven't provided the model I'm not certain your equipment has a caps lock light, as not all keyboard do.
Assuming it just doesn't have one this little piece of software(link below) could be the solution for you, it provides a little indicator in your system tray as to whether caps lock is enabled or not.
Caps Lock Indicator
Mar 19, 2014 | Computers & Internet
CANT TELL IF MY CAP LOCKS ARE ON OR OFF WHAT DO I NEED TO SELECT TO KEEP THIS FEATURE
if your caps light is on a light will/should show on your keyboard
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/numcapsscroll-indicator/3000-2072_4-10604212.html
On-screen real-time indicator showing the status of the Num, Caps and Scroll Lock buttons on the keyboard. NumCapsScroll Indicator monitors their status and indicates it in the System Tray with its icon, with a tool-tip when you mouse-over its System Tray icon, with a small On-screen Keyboard-like panel and a sound indicator. It's also an identical utility for laptops that are not supported with Num, Caps and Scroll Lock LEDs on their Keyboards.
What's new in this version: Version 7.0 is compatible with Windows 7.
Apr 06, 2011 | Computers & Internet
Is there supposed to be a caps lock indicator on HPw2207 keyboard,? If there is, I must be missing something I can never tell if I am in upper or lower case letters ( not too good when entering a password)
That model goes to a LCD monitor, not keyboard. Windows can make a tone when you hit the cap locks, so you can use that as indicator or you can use the on-screen keyboard which should visually show the cap locks being pressed.
How to tell when you hit the cap locks key
Windows On-screen keyboard
Mar 25, 2011 | Computers & Internet
Is there a light that should come on when I press the num lock button? I can't tell if the number lock is on???
It depends on the keyboard model. Some have a number lock indicator light. There is no standard for location, either. The most common place for Caps lock, number lock, etc. on a desktop keyboard is behind the number key pad. However, some keyboards put the caps lock indicator right in the Caps lock key. There's probably at least one model that does the same for number lock. Many laptop models have no indicator, or a tiny one set somewhere in back bezel.
Some operating systems and applications have an option for displaying the status in the menu bar. If you can't find the number lock status indicator, you may have to resort to observing the behavior of the system when you hit a key on the number pad. If number lock is off, the even numbers (not including 0) will be arrow keys and the odd numbers will be page navigation keys.
Jan 20, 2011 | Computers & Internet
Where is the light indicating that the caps are on?
It is usually a little A in a padlock. the easiest check is turn them on then off and see which light changes.
Dec 14, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Cap Lock on or off
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Feb 11, 2009 | Logitech Cordless Desktop EX110
Meaning of indicator lights on wireless receiver
I concur 2/3's with yooperbud.
1 = System is connected and working
A = Cap locks On= Cap lock is on. Off = Cap lock is off.
F = Function Key usage. On = I'm going to use the alternative fuctions of the F keys as programmed in the Keyboard settings. Off = Your using the standard features of the F keys.
Dec 31, 2008 | Microsoft Wireless Optical Mouse USB...
Logitech EX100 967499-0403 Keyboard Logo
1,091 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
