Heater will not stay lit, 35000btu propane
My unit only stays on while holding in red gas flow button larryl19472000@yahoo.com
  • Heating & Co... Master
  • 2,887 Answers
Try cleaning the the tube's to the presssure switch might be blocked
Posted on Jan 10, 2009
    Problem Solver:
  • 7 Answers
Larry, based on the description you have a bad heat limit switch or bad thermocouple. If you want to repair yourself, I can email a document that will assist you in troubleshooting the issue. emial me at heater_tech_42101@yahoo.com.
David
  • David Hagans
    David Hagans Mar 29, 2009
    THere is no pressure switch on this heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 02, 2010 | Teledyne Laars Laars Lx Pool Heater /...
Heater won't stay lit.
Change out the thermocouple, this will take care of the pilot problem. Very easy to take out and change.This is what keeps the pilot on and when it fails, no pilot. Sincerely, Shastalaker7
Nov 06, 2009 | Reddy Heater RLP100 Portable Forced Air...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Dec 08, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
